Any Help is Appreciated!!! - Boost Forum
Thursday, August 10, 2006 4:11 PM
OK, as you now i ordered the HAHN stage 2 kit. Now can anyone tell me is there anything else i NEED to have to run this setup? as in do i need to buy boost controller? do i need to buy gauges?, Clutch? Links to any good deals on these items? Like these things are thing i will defintely buy in the future, but i was Just wondering if I NEED them right away to run this setup. I have about 60,000KMS or about 39,000 miles on my car. Does anyone also know what kind of PSI i would be running around with Hahn stage 2 setup? thanks
<img src="http://www.j-body.org/registry/cav13/Chris-Cav-004.jpg">
Re: Any Help is Appreciated!!!
Thursday, August 10, 2006 5:13 PM
The hahn stage 2 setup allows you to boost up to....up to 6-8 psi. A boost controller is a good idea in my opinion. As for gauges your going to need a wideband a/f ratio gauge such as an AEM UEGO or a Innovative Lm1to monitor your a/f ratios under boost and also for tuning purposes. Boost gauge of course and a fuel pressure gauge to see what psi you are at idle and under boost. I have a AEM UEGO, Autometer boost gauge, and a Autometer electric fuel pressure gauge which can be mounted inside the car. A clutch is not a must right away but over time it will start to go and need to be replaced. It all depends on how much psi your going to run. Also look into some champion spark plugs from Hypsy. IM running 8 psi daily right now and i have 59,000 miles on my ecotec. I purchased all my products from Summit racing and reputable sellers on ebay but look at Hypsy's website and email him and see what he can do for you. Team Vision Racing
Thursday, August 10, 2006 5:49 PM
I'm not sure if he would NEED all of those things. Those things Blue Splash said are all good ideas, but not dire necessities. The wideband 02 gauge should be first on your list I think.
Thursday, August 10, 2006 6:36 PM
Hi, i thought that the STage 2 was supposed to run between 8-10 PSI...
