Hey guys I just wanna know if somebody as a picture for of the charger installed. I found some but no one as one from the pulley side that's what I need. this is stoping my progression on the install dam it !!
weel thanks to you all !!
Ben
stupid question , WHY ??
97 is no different looking than any of the others
I don't realy care about the year i just put it there for no reason I know it's all the same from 1996 to 2002.
Then again do you have a pic of the lower front to ??
Actually, the blower is ment for 2000-2002, but will fit 96-99, check the sticky.
my s/c is a proto type , so its a little different underneath
What's the problem you're having?? Maybe we can help you more effectively if you just tell us that
I know the tensioner is different between 96-98 LD9's and the 99-02 LD9's. Same with the starter (I've been told there's actually 3 starters.... 96-98, 99-00, and 01-02...'ish)
I did realy have a problem I had to figure out how the idler pulley needed to be installed. With the pic I figured it out. thx !!
I 'll be installing the blower today that's the next step. I got it on ebay and don't have the instructions.
anyway . I mounted the brackets change the starter, I made a block off plate for the egr i'm actualy at cuting the brake booster vacuum line.
