New engine and s/c - Boost Forum
New engine and s/c
Wednesday, July 12, 2006 10:38 AM
Now that i have all my suspension basicly done i want to work on my engine. I want to buy a brand new engine to work with and build it from the ground up. Were is a good place to buy crate engines?
Also this is the s/c kit i have to work from correct?
http://www.paceperformance.com/index.asp?PageAction=VIEWPROD&ProdID=237
I have a 96 cava
I looked in the sticky and found links to guys who posted all the parts i need to buy on top of the kit to get it to work on my car. I just want to get a new engine and internals and do it right the first time
Thanks for advice.
Re: New engine and s/c
Wednesday, July 12, 2006 10:49 AM
SO let me get this straight. You want a brand new motor (never ran) so you can build it? If so why? It will cost you about 3k from a dealer to get a brand new motor. PacePerformance sells them as well for around $1500.00. If you are going to build the motor get a used, blown motor and build it cost much less.
Wednesday, July 12, 2006 10:55 AM
^^ Exactly, I bought my motor and trans for 700.00 with 60,000 miles on it, tore it down, collected parts for abut 4 months, engine shop at the engine for 2 months(ughh) now im putting it all back together. Buy a motor from a yard, tear it down and build it up like that.. Will cost you much less going that route.
Wednesday, July 12, 2006 11:04 AM
cuz new one well will be new... Rather use new stuff and tear it apart and put new performance stuff in it..
Wednesday, July 12, 2006 11:20 AM
Topsub wrote:cuz new one well will be new... Rather use new stuff and tear it apart and put new performance stuff in it..
What are your plans for the motor? If you are tearing a motor apart then everything should be new, when your done. If you are going to build a motor for boost then you want new piston's, rods etc... The only thing that would not be new is the crank, and you can buy that without a whole motor. I would even suggest buying a blown motor from someone off the org. People are always selling motors that nedd rebuilt. You willbe wasting some serious money on a new motor and wasting a good motor as well.
Wednesday, July 12, 2006 11:26 AM
i want to go s/c.
Wednesday, July 12, 2006 11:34 AM
read up on building motors more and u will see why buying a brand new motor would be very stupid.
Wednesday, July 12, 2006 11:35 AM
You say you want to build your new crate from the ground up, but building from the ground up means you have to tear it down first.. That being said, its the same as building a blown motor and building that with brand new stuff.. Once you tear down your brand new motor, you wont be using those internal parts anyway.
I just dont get why you say you wanna use new stuff, then tear it apart to put MORE new performance stuff in it.
Wednesday, July 12, 2006 11:39 AM
Like everyone said, you will be spending more money. Either way, you're going to have a pile of stock engine parts you won't be using when you are done building it, so you might as well spend as little as possible on those parts.
Rob
Sold 2/2/05
Wednesday, July 12, 2006 9:23 PM
i think he is talking about wanting a new block it self...and my words of advice as far as that goes is go and get a blown motor....tear it apart, and wash it...send it to the machine shop and you will have a "new" block to begin on...its your best bet, cheapest bet, and if you pull it yourself, its your easiest bet...
Thursday, July 13, 2006 5:58 AM
^^ ya that. I just don't want take chance of the block being messed up. The only bad part is i have to have a shop do i tall cuz i don't have hte know how. I looking to drop 10 grand into the motor..
Thursday, July 13, 2006 7:14 AM
Topsub wrote:^^ ya that. I just don't want take chance of the block being messed up. The only bad part is i have to have a shop do i tall cuz i don't have hte know how. I looking to drop 10 grand into the motor..
It shows you do not fully understand or have the know how to do this. That was not meant as a flame towards you. In any engine build you should have the block hot tanked, and checked. They can check the block to make sure it has not issues. Truly unless it has a hole in the side of it, and if it is still stock internally you should not have any issues.
Thursday, July 13, 2006 3:58 PM
ur right i dont' understand.. thats why i was thinking buy new engine and won't have to worry about checking everything cuz its brand new.
Thats also why i am having a shop do it all Basicly i want to buy all the parts and drop it off at the place and say.. do it
Thursday, July 13, 2006 5:04 PM
Topsub wrote:ur right i dont' understand.. thats why i was thinking buy new engine and won't have to worry about checking everything cuz its brand new.
once again you arnt going the be the one checking it, the machine shop is. THEY will hot tank it, THEY will check for cracks, THEY will bore the block out if anything is wrong.
and have you evne priced anything out?? if you manage to spend 10k on a motor you will at that point manage to get totally railed in the ass.
Thursday, July 13, 2006 6:01 PM
Again I'm not trying to flame you, but help you. Truly regardles if the motor is brand new or not if you take everything to a shop and say build it with these parts, if they did that without checking the block for problems, then you do not want them building your motor. Regardless of age when building a motor you should inspect all parts.
Friday, July 14, 2006 6:09 AM
^^ ah.. got ya..
so pick up a blown motor from the yard??
My understandin blown meant busted block. but i guess thats not always the case.
Friday, July 14, 2006 8:29 AM
Topsub wrote:^^ ah.. got ya..
You can get good running motors from the junkyard also, does not mean its blown just cuz it came from a wrecked car.
Friday, July 14, 2006 1:01 PM
He is correct. Blown motor does not mean the block is cracked. Many things can make a motor be blown. Check the classifieds for people seeling motor, someone is always selling one.
Friday, July 14, 2006 2:26 PM
I bought a junkyard motor/trans/supercharger with only 22K on it, runs great! The only problem I had was the DIS was fuct and the wiring harness was aswell. Other than that, the motor and trans and charger run beautifully.
Scott
When I boost, you boost, we boost
You have been banned from NEJBODY.
You've displayed wayyy too many acts of pushing people to their limits.
It's never cool to tear people down for what they want to do.
NEJBODY is a team. We're not the same as JBO where everyone bashes on eachother.
I'm surprised you show up to our meets after half of the things you say on here.
Friday, July 14, 2006 2:29 PM
Make sure you look into what you are doing when you build it. If you are goin with the m45 charger then I wouldn't suggest lowering compression, maybe even raise it by a half, make sure the oiling system is up to par. etc etc etc.
Scott
Friday, July 14, 2006 2:39 PM
In acouple weeks, im going to have a 96 Z24 engine for sale. 116,000 miles on it. Ran great up until i blew my last tranny, the only thing is its sat for awhile. Last time i started it was a little under a year ago. I just picked up a 99Z motor cause i wanted something a little younger and i dont plan on building it up. Id sell it cheap if your interested in a used motor for building up.
Friday, July 14, 2006 2:48 PM
chris, didn't I beat you out for that setup? Did you ever get that other one that I told you about or did you just say fawk it?
Scott
Friday, July 14, 2006 6:49 PM
said fawk it, bought a 99 z front clip today and a RSM s/c kit acouple weeks ago.
