00' 9-3 Saab turbo on a 00' 2.4 - Boost Forum
Saturday, July 08, 2006 9:44 AM
did a search didnt find the info i needed though, looking to put out about 7-8 psi will this turbo do the trick, im still pretty new to this and im trying to peice together a kit to save myself from paying $3000+ for a built kit i found a 00' 9-3 saab turbo used for like $150 seemed like a good deal but will it do what i want it to if tuned correctly without doing internals?
Re: 00' 9-3 Saab turbo on a 00' 2.4
Monday, July 10, 2006 4:17 PM
I believe the SAAB 9-3 turbo/manifold fits on a ecotec, the turbo would be an appropriate size, for lower HP numbers,
Monday, July 10, 2006 5:32 PM
The 00' 9-3 turbo doesn't fit anything J related.
You would need the correct flange for the manifold. (for the saab turbo)
Monday, July 10, 2006 8:52 PM
what manifolds do fit the 3rd gens? or is it a custom application?
Monday, July 10, 2006 8:56 PM
Monday, July 10, 2006 11:22 PM
john engvik wrote:what manifolds do fit the 3rd gens? or is it a custom application?
the 03+ saab 9-3's with the ecotec engine. (Not ecopower)
