I have just bought a turbo, a manifold, and a 10:1 vortech fmu, bov, wastegate, and all pipings. I have a 2000 cavalier with the 2200. what else am i going to need to run at like 4-5 psi also it is a turbo. last is the 10:1 vortech fmu going to work or am i going to need to get a smaller one. will z24 injectors help. thanks in advance
sorry i meant to say 4-5psi and it is an auto. sorry
u will need a smaller fmu disc. i would recamend buying a cartech.
DRIVE HARD OR DONT DRIVE AT ALL!!!
FMU is fine just get a 4:1 or 6:1 plate, and tune from there, BEGI is nicer, but if you have that it will work, ,lots have done it. not sure if you have top feed injectors, but if you wanna go larger you need to lower your base fuel pressure
why not just spend the 60 and get the car tech its adjustable.
but its doable ethier way.
Kick azz is my boost hero!!!
well am i basically on my way. if i go witha 6:1 disk will i be ok to run up to like 7psi. also i have another 2200 motor that i am looking to build to ge tlike 300 hp so where would i start with that i have a garret t3 with .57 trim and .63ar
Not to thread jack but... I have a T3 42/48, internalt gated set to 8psi. My FMU is set to 10:1 I think. Is that going to be ok or should I change it out to something eles?
