2200 boost guys, oil gauge - Boost Forum
Sunday, June 18, 2006 11:52 AM
I didnt really find the answer im looking for. Where did you guys with the 2200 engine hook up your oil preasure guage?
Re: 2200 boost guys, oil gauge
Sunday, June 18, 2006 12:36 PM
where the stock sender is
Sunday, June 18, 2006 3:04 PM
can you tell me where that is?
Sunday, June 18, 2006 3:52 PM
there's a 1/4"NPT hole on the back of the block right above the oil filter.
it 'should' use a 1/4 drive square head to pull it out. (just a 1/4 drive rachet and extension, no socket required)
autometer provides a 1/4"NPT male to 1/8"NPT female fitting for our application.
Sunday, June 18, 2006 4:03 PM
any real easy way to access it? Its a PITA to get back there sometimes.
Sunday, June 18, 2006 7:45 PM
It's easier to get to if you pull the intake manifold. I've never done it on a 98+ though...'02 would want to pull the ECM for sure.
Nate (C22t/C24na) used to have a good pic of the plug in his reg, but took it down a while ago (luckily I saved it).
right is up:
I also found a pic of Tony's manifold if anyone is interested.
fortune cookie say:
Sunday, June 18, 2006 7:49 PM
what do you mean pull the ECM
Sunday, June 18, 2006 7:51 PM
also stupid but i figured i need to drain the oil to do this right?
Sunday, June 18, 2006 10:01 PM
no, you dont need to.. all the oil should scavenge back to the pain minus some residual oil.
do it when the engine is cold
also, if you've got a 5spd its pretty easy to jack the car up and get back there from underneath.
I was just there today fitting up my oil pressure/turbo feed line
good luck.
Monday, June 19, 2006 2:02 AM
if your car is auto it is also easy to get to by removing your exhaust before the cat..... you have a very convenient hole from where a 2.4/2.3 exhaust would normally come from that you can get up into.
Cardomain|Myspace
Monday, June 19, 2006 8:11 AM
ill get right on taking my exhaust off minion
Monday, June 19, 2006 10:18 AM
stevefire wrote:there's a 1/4"NPT hole on the back of the block right above the oil filter.
wow
thanks for the advice....
just went outside.......
found the plug in like 2 seconds (just crawled under the car, got it out with ease.......
taped the fittings and installed it ..... (I had the gauge and line already run .... just not tapped).......
took 15 minutes...... running at cold start up 62.5psi oil pressure.... (block pressure)
thanks STEVE !!! YOU ROCK !!
Lee
JDM Civic Hatch
Monday, June 19, 2006 1:06 PM
nice, glad to hear I'm not the only one using it
Monday, June 19, 2006 6:11 PM
thats what i'm using for my oil psi gauge and oil feed for my turbo.
Monday, June 19, 2006 8:25 PM
how long have you been boosted? any problems?
I should take a picture of my setup, it'd be interesting to compare.
Wednesday, June 21, 2006 10:00 PM
I plan to use that same port for my turbo feed, but i have my oil pressure gauge off the same spot that the oil pressure stock sender unit is at. it's the the left of the oil filter.
Pic: see the breass fitting? i used that.
