Reflash P/N for auto and manul - Boost Forum
Tuesday, June 13, 2006 9:43 PM
Okay, I down loaded th ebuild guide from the gm performance web site. Inside the chapter of "Engine assembly stock to 250hp" it gives you the part numbers for the reflash for both automatics and manual. So here they are: 12590819 for automatic transmission /
12590820 for manual transmission. This is straight out of the ECOTEC Build Guide. So if anyone is having trouble getting the reflash numbers now you should have them, unless they have changed them since the guide was published.
Git er' done!!!!
Re: Reflash P/N for auto and manul
Tuesday, June 13, 2006 11:06 PM
that is just a part # , dealer still has to call to get VCI #
Wednesday, June 14, 2006 8:36 AM
not to mention if you take that number to parts it comes up as
" not found in master GK catalogue"
noble effort though
*************Yea i spell liek wrong get over it*****************
** If i write in caps its cause im @ work and i can only write in caps cause the keyboard is a retarded CAPS only keyboard.**
Wednesday, June 14, 2006 9:19 AM
All about VCI numbers:
http://www.j-body.org/forums/read.php?f=30&i=27943&t=27943#27943
The link to look up your VCI number from your VIN no longer works.... too bad
Wednesday, June 14, 2006 9:21 AM
Oooh... look what I found
http://tis2web.service.gm.com/tis2web
I don't have my VIN handy to check if it works or not tho....!
Wednesday, June 14, 2006 12:13 PM
I have my VIN numbers but ahere at work the computers will not support the web site. So that will have to wait until I get home. But I think that it may give us something.
Wednesday, June 14, 2006 1:12 PM
You can also use http://calid.gm.com
Wednesday, June 14, 2006 3:04 PM
This is what I just found out. I got it to where this computer would accept the scripts froom the website. It gave me these numbers for the PCM/VCM:
Part Number Cal.ID# CVN Description
12598563 12598565 N/A New calibration to ensure proper catalyst monitoring at idle.
12593508 12593510 N/A Control module calibration
So I am guessing that it worked, these would be the Cal ID for the reflash for my specific car.
