well I'm working on installing everything, today I went apulled the fuel rail, was getting ready to to swap out the injecors and what to I find... my injectors have somehow turned up missing!! The magically disapeared from next to the polished fuel rail I had sititng on my shelf.
sooooooooooo
I'm in need of injectors, and any connectors I may need to swap over to the harness so I can plug them in.... looking for about 10 psi... what should I get and where should I get it? if I don't need to to swap wiring wiring thats good, if I have to no big deal. Also they need to fit an 04 ecotec fuel rail and do I still use the injectors buckets in the head or take those out? Any help on what to get and where to get it is apreciated.
by the way a friend is selling some high impedence 420cc Ford Green tops.... yes or no?
420cc should be fine just as long as tey are 12ohm
the 420 are gonna idle like crap , unless you get the hp tuners and adjust for them that way
the 1's with the kit are 320 or right around it
if anything just get the 2.0s/c or gm eco s/c kit injectors , they are around 370 , and plug in and fit with no mods
Yay!
I found them
aperently people like to clean up my things and "put stuff away" found injectors in the drawer with batteries and @!#$ wjhile trying to find some for my flashlight
so next question..... these injector harness plugs.... any idea who makes them and or where I can find the metal clips for the connectors?
junk yard , of any older GM car
stick in your pocket , cost = gas to get there , money to get in and a soda
yeah I did the same thing I took an injector to the junk yard and just started stuffing them into clips until one fit.
Kick azz is my boost hero!!! "
[quote=97cavie24ls(JDM&00s/c sedans™)]the 420 are gonna idle like crap , unless you get the hp tuners and adjust for them that way
I'm idling 440cc on 20-23PSI just fine. The eco ECU as is can do some amazing compensation. We had the car idling PERFECT at 60PSI on the 440s.
5K PB: 24:50
10K PB: 54:26
