Auto Eco Track times - Boost Forum
Wednesday, April 26, 2006 7:34 PM
Well I just got back from the track for the first time ever to run my car. My best time was 14.827 at 92.89. Temp was 65-68ish pretty nice except for the fairly strong headwind. My buddy usually runs 13.0xx in his Transam pretty consistantly but wasnt about to get under 13.30x for the day. Overall I am pretty satisified with the time, I was hoping for 14.6 but not too bad I guess. The car has the Eco charger, motor mounts, and the Megan Catback. I did also have my intercooler all hooked up and running. Now its time for the full exhaust, intake and 3.0 pulley. I just wanted to see where I started at before bolting more on.
Check out my car....
http://members.cardomain.com/o4blackfire
Re: Auto Eco Track times
Thursday, April 27, 2006 6:47 AM
a 92 MPH pass? Isnt that like a 14.6ish pass anyway?
Thursday, April 27, 2006 7:01 AM
wow, times for the charger are all over the place.
Thursday, April 27, 2006 7:57 AM
What size is the stock pulley if a 3.0 pulley would be smaller?
Thursday, April 27, 2006 8:43 AM
this should be in the racing fourm
you gotta be doing something wrong if your only running mid/high 14's
my 2.4 has run a best of 14.38 @ 95 , and that is with less boost , and im sure with drag radials i could get it alot closer to the 13's
being most eco auto's run equal or slightly better than 2.4s , i would have expected to see alot better times from a car with 5psi more boost
post up your whole time slip
im not hating on ya , just saying something is off more so than normal
Thursday, April 27, 2006 9:13 AM
Any bits of advice are cool with me.
Heres copies of 2 slips
r/t- .495 .583
60- 2.334 2.171
330- 6.288 6.191
1/8- 9.530 9.501
MPH- 75.28 73.79
1000- 12.401 12.434
1/4- 14.827 14.917
MPH- 92.89 91.50
Also if mods would move this to the proper spot thatd be cool.
Thursday, April 27, 2006 9:32 AM
i didnt see much for mods in your reg
but here is a few things id get (providing you dont already)
larger tb 60mm minimum
make a custom 3" intake , cold air only
shift plus or auto trans
header back exhaust , 2 1/4" or 2 1/2" (im still using 2 1/4" and havent maxed it yet)
adjustable struts , set rear near full stiff , and front soft
better tires for drag racing
your 2.1 60 is pretty decent , id try and work on getting off the line as quick as possible , with as little wheel spin as you can , youll want a little
on mine i have it stalled at 2500rpm , and my foot is flat on the floor , creating a bog when i first take off , it keeps my car from smoking the tires
and mine i shift as close to the rev limiter as possible (6500) , i shift mine manually
ill post a few of my slip later so you can look them over
Thursday, April 27, 2006 10:12 AM
Great Advise, Eric - I will be taking some of it as well. I am looking forward to seeing those slips.
Check out my Part Out List!! Great Prices !! http://www.j-body.org/classifieds/detail/52925/
Thursday, April 27, 2006 1:29 PM
i try , lol
but with anything , its all a learning curve , each car , track and situation is different
i said that with encriptor(econator) when he was disappointed with his track times , you just gotta relearn
and having more info always helps
Thursday, April 27, 2006 3:50 PM
elevation at his track could play in too... i'm not sure how much variance there is in different parts of michigan but i know there was a big difference between NJ and the Indy Bash last year for PJ and Mandy's cars... Trap speed was down like 2-3 mph from normal.
Arrival Blue 04 LS Sport
Eco
Turbo
Megasquirt
'Nuff said
