dumb newb question about wastegate - Boost Forum
Friday, April 07, 2006 10:05 AM
alright the external wastegate i have has to fittings for vacuum, one on top of the wastegate and one on the side..i know one goes to a vacuum source to control boost, but which one and where does the other one go?
Re: dumb newb question about wastegate
Friday, April 07, 2006 10:13 AM
The side is where you hook up the vac source, the to is the vent. You can also install a fitting to the top to hook up a MBC.
Failure is not failure if you learn from it
Friday, April 07, 2006 10:14 AM
Top is the vent, damn not EDIT
Friday, April 07, 2006 11:24 AM
vent what?
Friday, April 07, 2006 12:27 PM
you dont have to hook anything to the top...just leave it open. hook a vacuum/boost source to the side fitting.
_________________________________________
450WHP Turbo Ecotec swap in the works...
Friday, April 07, 2006 9:21 PM
It the vent for letting out the pressure when the WG opens. If you restrict it/block it it'll cause the wastegate to not open or open late.
Friday, April 07, 2006 9:42 PM
02turbo wrote:It the vent for letting out the pressure when the WG opens. If you restrict it/block it it'll cause the wastegate to not open or open late.
Learned that the hard way lol
Monday, April 10, 2006 7:21 PM
ya just leave the top open and clear. and hook up your boost signal to the side.
