just dont know where the oil feed line should come from for the turbo, and is it okay if i run a cooler just before the turbo.
i gotta 95 cavalier, but im swapping out the engine for a 2002 2.4. wiring and all, i got a t3 wet float turbo and im getting ready to put it all together but jus not sure where the feed line should come from.
if your swapping to the 2.4 the use the oil pressure tap between the cam towers. there really is no need to run an oil cooler before the turbo. if you want to keep the turbo cool (and you should) if your turbo has the water ports, use them! you can T off of each of the heater lines and run it thru the turbo to cool it and keep it from destroying your oil so quickly. if you clock the center ever so slightly it will actualy casue water to flow slowly thru it when hot even when you turn the car off like many oem turbos do.
99 Turbo Sunfire GT | Ram 2500 | International Rollback | Mr Hanky the Suburban
