turbo..what all do i need? or should i just go with a suprcharger for my 2005 cavalier....all i know is that i need boost! my car is compleatly stock as of right now(just bought it a week ago) and iv been hanging out wiht a group that is nothign but turboed everything...i gotta be able to keep up
I <3 3COT3C!
![](http://www.teamethnix.com/viscavigraphic.jpg)
www.IZNTRBL.com
apparently you want a factory gm supercharger kit, installed, and pretuned.
i looked at the FAQ'S...but i wanted to see if there were was anything else too get...im pretty sure i want to turbo...am i gnna have to do internal work right off the bat..or will i be safe with a turbo setup ,BOV ,injectors, intercooler....i only wana run like 5psi
I <3 3COT3C!
www.IZNTRBL.com
travis maser wrote:i looked at the FAQ'S...but i wanted to see if there were was anything else too get...im pretty sure i want to turbo...am i gnna have to do internal work right off the bat..or will i be safe with a turbo setup ,BOV ,injectors, intercooler....i only wana run like 5psi
if you did in fact read the FAQs, you'd know the asnswer to that question
