i was thinkin of the best way to run the oil lines, and i figured the best thing to do is buy an oil cooler with the adapter for the filter with the feed and return ends on it. and i would just run the feed line to the cooler then out the cooler and to the turbo, then out the turbo and back to the engine via and the adapter from the oil cooler. would this disrupt the oil flow in the engine though?
no thats a real bad idea the return side of a turbo is zero pressure just a drain back so u will end up blowing all your oil past the seal in your turbo and into your exhaust as soon as u start your car your car and half the block will disappear in a cloud of blue smoke.
