Like the title says, I have searched cuz I have seen this topic on here before but couldnt find it, but I was wondering on how to get low impedence injectors to work with a 99+ pcm, and the directions to do so, if anyone could post a link of the topic or if they know how it is done explain, thank you much, adios
I talked to the Tech people are RC yesterday for about 1 hour.
If you have low impd. injectors you CAN run high impd injectors are the car but it is still recommended that you run the correct injectors on the car.
If you have high impd injectors you can ONLY run high impd injectors on the car. From what they said, you can not convert it anyway to make the low impd injectors work on the car correctly.
Did they give any info on how to go about that, is there even a need for the resistor? I dont imagine taht you could simply plus and play going from high impedence injectors to low impedence.
