if i do my piping with aluminum will it be sufficient enough for boosting or am i forced to go steel?
i bought a hks bov flange for 2.5 piping in aluminum and i didn't think twice about what kind of material i was doing the piping in .
my mistake
but hopefully aluminum will do the job!
any info you need
i am using T04E turbo
intercooler- undecided
aluminum may be a bit more expensive to get welded but nothing ridiculous. You could always switch to steel later if you need. ALuminum dents easily i did all my stuff in steel. Its a bit heavier but i like it.
*2012 mazdaspeed3*
good to go buddy!! You can powder coat aluminum with heat resistant coating if you want but aluminum is fine
Play hard, Drive fast, and Be safe...
thanks guys for the feedback !!!
Where did you guys get your aluminum piping from?
aluminum piping
horsepower is how hard you hit the wall, Torque is how far you push the wall with you
heres my pipes i made for my dsm
96 bucks to get it all welded up....4 pipes welded together
Mild Steel is just as good and cheaper. That's what mine is.
most of mine is aluminum. all of it recycled junk. saab & volvo charge pipes, some exhaust parts, and a hacked up aem cold air intake for a honda make up the charge pipes
oh yea and my intake is made from a bend from a ford intake, a leaf blower extension, an elbow from a 2.2 WAI and a ricer-esk cone filter. it was cheap and it all works just fine.
99 Turbo Sunfire GT | Ram 2500 | International Rollback | Mr Hanky the Suburban
Josh Csepegi (CUYOTE) wrote:
aluminum piping
that is crazy rigged
its custom man leave it be... Im just playing as long as the boost gets there whatever right.
*2012 mazdaspeed3*
LOL it's different now all the mandrel bent alum... LOL thanks though
f'n sweet
Clocking the compressor is your friend!~
I usually use mild steel when I build turbo cars. I built a turbo civic for someone this week and used aluminum.. it is all prefference and how much you want to pay. If you want to be cheaper get just one small aluminum tube and have the bung welded on then do the rest in mild steel.
Cardomain|
Myspace
haha I tried to clock the turbo and it only clocked in 45 deg options..
so I had that position, straight down wich ran into the down pipe,into the radiator(not a good idea), and straight up(even though this would look cool not that good for flow).
