I have an 03 cavalier and am getting a dual pillar pod what gauges should i have i it if i am goin to run a turbo? boost and......?
well youd prolly like more then just dual pillar...boost of course,oil pressure would be good, a/f if you have a wideband, maybe egt, fuel pressure..thats all i can think of right off the top of my head..hope that helps..phil
really to be honest all you need is a 02 wideband
I have everyguage under the sun and all I ever look at is my 02
this is of course ireallavint if you plan on running high HP
Kick azz is my boost hero!!!
Boost/ wideband/ egt/ if your doing an fmu fuel pressure gauge is a must for tuning. Depends on your hp number if your looking to like 200hp then the first 3 would be best but it all depends on whether or not you know what those gauges mean. Are you new to boost or do you know what your doing? Gauges are great because they are informative but if you dont know what any of it means then why have them. Good luck to you though hope everything goes smoothly for ya you will love boost.
*2012 mazdaspeed3*
Im going to be running an FMU in my setup so i went with a boost gauge, fuel pressure gauge, and an AEM UEGO air fuel gauge that monitors the air fuel ratio. The fuel pressure will allow you to see your fuel pressure at idle and under boost.
Wideband and Fuel presure is best under the hood so you can tune easier. I like it anyway...
Play hard, Drive fast, and Be safe...
SRTKILLER wrote:Wideband and Fuel presure is best under the hood so you can tune easier. I like it anyway...
But you can't look at the fuel pressure gauge when you're driving. Unless your doing something really.... dangerous., or have a dyno...
