Is this Everything - Boost Forum
Is this Everything
Wednesday, March 29, 2006 6:45 AM
I want to order everything at once and i want to make sure i have everything based on the faq
MSD DIS-2 Plus Ignition Control - 399
http://www.turbotechracing.com/productcart/pc/viewPrd.asp?idcategory=385&idproduct=2707
RC Fuel Injectors - 339
http://www.showstoppertuning.com/store/product.php?productid=17076&cat=1023&page=1
NGK Spark Plugs ( 4 ) - 14.99
http://www.showstoppertuning.com/store/product.php?productid=17130&cat=1029&page=1
gmparts for s/c - 258.
1999-2000 2.4L AC Delco Starter ( GM Part # is 10465386 )
1999 2.4L EGR Block-off Plate ( GM Part # is 24575505 )
1999 2.4L EGR Block-off Plate Gasket ( GM Part # is 24573947 )
1999 2.4L EGR Block-off Plate Bolts ( GM Part # is 11517518 )
Thermostat
JET 180ø Degree Low Temperature Thermostat Cavalier/Sunfire - $20
http://www.turbotechracing.com/productcart/pc/viewCat_h.asp?idCategory=374
Supercharger
http://www.paceparts.com/index.asp?PageAction=VIEWPROD&ProdID=237 - $2389.95
MSD high pressure fuel pump ( inline) - $99.99
http://www.turbotechracing.com/productcart/pc/viewPrd.asp?idcategory=383&idproduct=778
Venom Fuel Rail - 169
http://www.turbotechracing.com/productcart/pc/viewPrd.asp?idcategory=383&idproduct=192
Hi Flow Aftermartk supercharge - (car-2027) -259
http://www.cartech.net/fmu2020.htm
total: ~$4048
Let me know if i am missing anything, or if i should use something else . I am new to this :-)
Re: Is this Everything
Wednesday, March 29, 2006 8:44 AM
Get the programmbale MSD.
The injectors you selected... what size are you looking for?
If you want 320s, make sure you get the right part because you need low impd. injectors.
Wednesday, March 29, 2006 8:46 AM
Karo (Car Customs) wrote:Get the programmbale MSD.
In the faq i saw they recommended them. thats why i selected theat.
Programmbable msd.. do u have a link by chance to make sure i select the right one
Wednesday, March 29, 2006 9:17 AM
Part number MSD-6212 is the programmable one.
As for the injectors, you need to figure out what size you are going with.
If you have questions or want more info just e mail me, I will do all I can to help you out.
Thanks.
Wednesday, March 29, 2006 9:36 AM
you dont need the thermostat , venom fuel rail and MSD.
Wednesday, March 29, 2006 10:48 AM
and if you were to go with the thermostate I would go with a 160 degree one
**changes are here**
Wednesday, March 29, 2006 11:57 AM
how do i decide what injectors i need? is there something to base it on?
Is there a reason to go with that one vs the other one? Just wanting to understand thats all
Wednesday, March 29, 2006 12:54 PM
How much power you want to make would be a good place to start....
What applicatoin are you going for? GM Charger?
If a GM Charger, Id say 320s should be fine for you.
Either way, e mail me, I have a few sets in stock for a real good price plus you get FREE S&H as well.
Thanks.
Friday, March 31, 2006 9:28 AM
Karo (Car Customs) wrote:How much power you want to make would be a good place to start....
Nothing Major, just decent amount
Yes Gm
Friday, March 31, 2006 1:14 PM
I think 320s will be good enough for what you are trying to do.
