Super Charger kit? - Boost Forum
Super Charger kit?
Sunday, March 05, 2006 5:02 AM
Ok, before I start, I want you guys to know that I searched this and came up way short. I could only find Turbro Charger info.
I am looking into getting the new charger for the 2.2 Eco Tech and have found the S/C itself. But are there any other parts needed for this?? Such as inner cooler ( I know this is optional but im using it as an example) or any thing else? A list would be really nice and like I said...I did a search and only found parts for a Turbo Charger kit.
Thanks guys, your always helpful.
Re: Super Charger kit?
Sunday, March 05, 2006 6:16 AM
search
Sunday, March 05, 2006 7:16 AM
Wow, you gotta be kidding me?? apparently you can't read. I said I already did. Thanks...
Sunday, March 05, 2006 7:49 AM
B Garay wrote:Wow, you gotta be kidding me?? apparently you can't read. I said I already did. Thanks...
There is like 10 Ecotec supercharger threads on this page alone.
Sunday, March 05, 2006 7:51 AM
Lets see here, Yes I know about those threds but my question is COMPLEATLY DIFFRENT then what they speak about. I need a LIST of parts. Once again READ ABOVE
Sunday, March 05, 2006 7:53 AM
Im not trying to be a condisending ass or any thing but geez asking some thing polite and you get treated like ur stupid. I swear this will be the last time i post to ask for help from children.
So what if it was a repost or what, just be cool and calm and help a guy out. Not asking you to go out of your freaking way to do something bad. Just a list. This is why I don't post much any more on here because people like you give a whole group a bad name.
GROW UP.
Sunday, March 05, 2006 9:15 AM
Cry all day, no one cares. The person that is going to answer your question, guess what he had to do to find the information? He had to do some research on his own to find it all. Everything you asked for is in this forum in one thread or another.
Sunday, March 05, 2006 12:18 PM
No kidding.
Why would they keep all the old posts on the board if you could just start a new one to ask all the same questions that already get asked once a week?
Everything you need is in front of you.
And bitching people out certainly isn't going to make them want to help you either!
But I digress...
14.330 @ 96.37mph
Sunday, March 05, 2006 12:22 PM
B Garay wrote:Lets see here, Yes I know about those threds but my question is COMPLEATLY DIFFRENT then what they speak about. I need a LIST of parts. Once again READ ABOVE
Download the new book that GM put out about the Ecotec. There is a picture by picture install on the GM Supercharger for the Ecotec along with a 100% complete parts list for it as well.
I will try to find you the link to the book later on and post it. I know its on GMs website somewere its like a 30 MB PDF file...
Sunday, March 05, 2006 12:23 PM
SUPERCHARGER PARTS LIST
PARTS LIST
Part Description Part Number
Supercharger Kit 1780003
Clamp - Fuel Pressure Regulator Hose-Intake Manifold End 10028454
Hose, Brake Booster 10358940
Nut - U-Nut Oil Level Indicator Tube Support 11507067
Nut - U-Nut Radiator Hose Support 11507067
Clamp - Coolant Hose Cap 11516226
Bolt/Screw - Intake Manifold Bracket-to-Engine Block 11516342
Bolt/Screw - Intake Manifold Bracket-to-Intake Manifold 11516506
Nut - Intake Manifold 11516076
Bolt/Screw - Radiator Hose Support 11516757
Bolt/Screw - Drive Belt Idler Pulley Bracket 11518048
Bolt/Screw - Generator Relocation Bracket 11518051
Bolt/Screw - Intake Manifold 11518062
Nut - Intake Manifold-to-Head 11518532
Bolt/Screw - Generator Relocation Bracket 11589134
Bolt/Screw - Drive Belt Tensioner 11589147
Bolt/Screw - S/C TO Intake Manifold 11589214
Bolt/Screw - Oil Level Indicator Tube 11589299
Bolt/Screw - Drive Belt Tensioner 11589312
Pin, Connector – Female 12048074
Connector Pin Seals 12048087
Lock-Connector - IAC Connector 12052634
IAT Connector Replacement 12052641
Map Connector Replacement 12110293
Zip Tie 12355066
Connector - PCV Tube 12581198
Tensioner Assembly - Drive Belt 12583180
Supercharger Assembly 12584331
Vacuum Hose - Fuel Pressure Regulator 12584337
Gasket - Supercharger Outlet 12584342
Manifold Assembly – Intake 12584348
Gasket - Intake Manifold 12584359
Bracket Assembly - Drive Belt Idler Pulley 12584364
Bracket - Generator Relocation 12584365
Tube Assembly - Intake Manifold-to-Fuel Regulator (LSJ Purge Valve Hose) 12584369
Brace - Intake Manifold 12586632
 GM SPORT COMPACT Performance Build Book 39
PARTS LIST
Adapter - Throttle Body 12590814
Belt - Accessory Drive 12590815
Wire Assembly - Map Sensor 12590818
Data File – PCM Engine Calibration 12590819
Data File - PCM Engine Calibration 12590820
Stud - Intake Manifold 12590821
Stud - Intake Manifold 12590822
Bolt/Screw - Throttle Body Adapter (M6 X 20 mm Socket Head Cap Screw) 12593676
Washer - 17 mm OD For a M8 Bolt x 4 mm Thick 12593677
Sticker, Carb E/O 12593900
Template - Intake Manifold Gasket Cut Out 12593902
Instruction Cd 12593903
Injector Assembly – Fuel 12593904
Plug, Map Sensor 12593906
Gasket - Throttle Body Adapter Plate (O-Ring) 12593905
Template - Dip Stick Tube Support Bracket 12593907
Support - Radiator Hose 12594613
Cap Assembly - Cool Hose 15544596
Cable Assembly - Cruise Control 22688111
Hose Assembly - Radiator Inlet 22718761
Vacuum Fitting - Waste Gate 24507839
Air Duct 24575436
Premium Fuel Decal 25602518
Sunday, March 05, 2006 12:49 PM
thank you karo. haha I needed that list.
Sunday, March 05, 2006 12:54 PM
i put on the gm 2.4 charger kit and it came with 100% everything to put it on, only took about 4 hours or so
Sunday, March 05, 2006 1:00 PM
Karo, Thank you very much for you effort in posting that for me.. Thats all I was asking for....as for the other lil @!#$ heads...was that so hard to tell me that it was in the BOOK? no . i swear you ask a question on here and you get treated like y our stupid...
Well then why even have this forum if all you gotta do is look for yourself on the internet. That makes no sense thats why you have a forum to SHARE INFO. other wise we wouldnt need your sorry ass Dunsmoor
Sunday, March 05, 2006 1:08 PM
mabey everyone was bitching at you because the info was readily available if you performed a simple act as a search on google or something. when i have a question, i google it, search for it here, and if i still come up emty handed THEN I make a post.
You'll never touch God's hand
I've seen the ways of God
I'll take the devil any day
Hail Satan
Sunday, March 05, 2006 1:20 PM
It takes MORE effort to BITCH at someone and tell them to SEARCH then to actually GIVE them the INFO which they asked for the begin with.
My 2 cents. Flame Away!
Sunday, March 05, 2006 7:40 PM
search is 1 word
take 5 seconds to do
doing a search takes a couple minutes
Sunday, March 05, 2006 10:03 PM
Once again I DID SEARCH AND CAME UP EMPTY!!!!!!!!!!!!!!!!!!!! DAMN .....Karo thanks for having more common sence then these imature kids.
Sunday, March 05, 2006 10:07 PM
you obviously didnt search well enough
or have your head out long enough to realize where the parts info was
Monday, March 06, 2006 1:35 AM
Karo (Car Customs) wrote:It takes MORE effort to BITCH at someone and tell them to SEARCH then to actually GIVE them the INFO which they asked for the begin with.
Monday, March 06, 2006 8:27 AM
i side both ways on this little argument however i will say that using the search on this website isn't nearly as easy as it is on various other sites. that google search thing sucks ass. some people aren't as adept at using the search as others would like. it's easier to help someone out and be friendly.
Tuesday, March 07, 2006 5:30 AM
Purplezed.....Thank you for the support on the friendly comment.
Thats all I ask. Im not asking for you guys to give me the answers.. just a lil nice nudge in the RIGHT direction would be nice, and telling me to search doesnt help. Unless your hitting key words that I dont know then its a lil more difficult then what you think.
Wednesday, March 08, 2006 8:30 AM
Seriously, I have been a member on JBO for 3 years and some things seem to never change. The guy said he already searched and didn't find anything. WAY too many people make USELESS posts telling people to SEARCH. If he said he already searched, don't yell at him. Not everyone has "God-like searching skills" as some of you think you have. If you don't have anything good to say, don't say it. It's no wonder that JBO gets a bad name with so many pricks that spend their time telling people to search. I've noticed that for alot of people on here, 90% of their posts contain some variation of "What's wrong with you, SEARCH!!" I don't see much help in that.
Props to Karo for helping out. He along with many others on JBO are very knowledgeable and are very friendly and helpful. So don't get me wrong, most people here are helpful. Its always a few bad apples that ruin the whole bunch.
Just my 2 cents.
1999 Grand AM SE (Beater Car)
1997 GMC Sierra
2007 Honda CBR 600RR
2005 Honda TRX450R
Wednesday, March 08, 2006 9:04 AM
Wednesday, March 08, 2006 9:08 AM
the info is out there , if he bothered to read through all the posts , he woulda been lead in the right direction
all the part #'s are in the install instructions , and there is a PDF file for it from GM off their site
how do i know that because it was posted here atleast once , as well as dave linked me to it
