rsm blower with a gm reflash - Boost Forum
Friday, March 03, 2006 12:27 AM
hey guys i was wonderin, everyone thats gotten the rsm s/c kit has complained about the reflash and fuel management, would that problem go away if the computer is running of the gm reflash, maybe establish a better tune out of it?
Re: rsm blower with a gm reflash
Friday, March 03, 2006 12:33 AM
I don't see why not. GM suggests that if you're boosted that you should get the Reflash (according to the GM Performance book) but the problem is trying to get the flash and Map sensor. I'm still trying to find out if you have to go to a certain dealership to get it done. There are other topics talking about it as well.
Friday, March 03, 2006 12:52 AM
if you didn't already have the rsm kit, pretty much anyone would have, at this point, advised against it... but yes, the gm supercharger reflash for the eco should work pretty well, there are some differences in the the boost/power curves of the two different superchargers so it won't be absolutely optimum, but probably a lot better than what you've got now. If you get it, do everyone a favor and go get some dyno runs with a/f readout and see what happens.
Arrival Blue 04 LS Sport
Eco
Turbo
Megasquirt
Friday, March 03, 2006 6:40 AM
doesnt the RSM kit come with a different map ensor or a 2 bar map sensor? Why not buy that seperate from RSM instead the one from GM....since the GM needs modification and is still hard to get at the moment. RSM use's a centrificle <sp> Charger so if the kit comes with a map sensor it should fit in the stock manifold???? This is shooting in the dark so I dont know!
Friday, March 03, 2006 7:28 AM
I've talked with a few folks with 03+ Ecos and the RSM Charger and Reflash. For the most part they don't seem to have any codes, misfires, or leaning out. It seems the 02 Ecotec is the headache with the RSM reflash. If you have the RSM reflash you might not need the GM one. Check your A/F ratios and then go from there.
Friday, March 03, 2006 9:34 AM
my friend here local in phx has a 00 grand am 2.4 with the rsm s/c and the gm s/c reflash
it ran pretty good , although i think he has a s/c problem now
his user id here is mike
Friday, March 03, 2006 12:07 PM
I know that Borgs car was programmed with the GM Reflash but was
running the Vortech Unit.
He was also using the Injectors and map sensor that came with the GM Kit.
All in all I was impressed for the 7 months I had it on my car.
Friday, March 03, 2006 12:23 PM
what did you do now borgs ???
it sounds like the vortec isnt on your car now ???
Friday, March 03, 2006 12:59 PM
Sold it last month.
Friday, March 03, 2006 1:10 PM
what are you doing now ???
or is it top secret ??
Friday, March 03, 2006 3:12 PM
i've heard the 02's had problems, i have never ran a single code for nething, the air/fuel is always pretty good. im hearing lots of complaints from ppl about the rsm kit but i have only had on problem with the kit and that was due to my local dealership messing up sumthing. the cars runs strong i just didnt know if it would be better to try and get the gm reflash
Friday, March 03, 2006 3:45 PM
yeah, I have an LD9 with the gm reflash and 2 bar map and 310's on an intercooled RSM blower. Works great except for the fact that the bearings on the end of the s/c shaft are @!#$ up now... It still works fine, but theres just a little vibration to it that kinda sucks. That, and the fact that the grand am's ABS box is located RIGHT UNDER the s/c, and the blower caused a brake line to get @!#$ up, and I needed to reflare it. I'll be switching to the m45 later this month, and I'll be selling the RSM blower for REAL cheap. I'll start a topic on it when I get it. I'll also be selling the 2 bar map and injectors that come with the kit, as I already have them.
Oh, and in the gm kit, are there brackets that are specifically used for the n-body and not the j's? cuz if I end up with extra brackets that are just for the j's, those will be for sale too.
sorry to hijack the thread
'00 Grand Am 2.4L LD9
http://www.cardomain.com/ride/816505
Friday, March 03, 2006 4:07 PM
BORGS wrote:I know that Borgs car was programmed with the GM Reflash but was
dude why are you talking about yourself in the 3rd person
is this how you pick up chicks now??
and i agree his car ran perfect with that setup
man that blow off valve sure did scare that crazy b!tch in the integra
Friday, March 03, 2006 7:53 PM
yet no 2003's have the reflash yet...it was just made available today. but as for the reflash for the eco...in theory it shoudl be the same as the 2.4 setup.but it seems gm is trying to make it harder by not being able to get the map sensor.
*************Yea i spell liek wrong get over it*****************
** If i write in caps its cause im @ work and i can only write in caps cause the keyboard is a retarded CAPS only keyboard.**
Tuesday, March 07, 2006 8:44 AM
That's strange. I distinctly remember Borgs both claiming to be running the RSM reflash, and standing behind it fully.
More mistruths? Say it ain't so!
14.330 @ 96.37mph
Tuesday, March 07, 2006 8:49 AM
That's what I was told until I hooked up the Tech 2 and saw the program never changed.
Actually neither did the map, injectors or the plugs.
Tuesday, March 07, 2006 10:53 AM
Well it depends on how the program adjusts fuel, does it use the map to determine boost pressure then add fuel accordingly, or does it add a static amount per rpm, i honestly cant tell you how either works
Wednesday, March 08, 2006 1:20 AM
BORGS wrote:That's what I was told until I hooked up the Tech 2 and saw the program never changed.
woot.... some more stealing and lying by RSM...
SPD RCR Z - '02 Z24 420whp
SLO GOAT - '04 GTO 305whp
W41 BOI - '78 Buick Opel Isuzu W41 Swap
Wednesday, March 08, 2006 7:23 AM
actually if rsm altered the info in the pcm already , the program code would still be the same
and yes i said IF
