what type of fpr to use? - Boost Forum
Tuesday, February 28, 2006 6:18 PM
i just purchased the j tuners turbo and intercooler kit for my 2200 sunfire and i was just wondering what kind of fpr is best to use . i'm only gonna be running 5 psi for now. i will be getting some 310 injectors . any help is greatly appreciated.
Re: what type of fpr to use?
Tuesday, February 28, 2006 8:57 PM
Not sure if the 310's will idle funky or not, but you could look into the accel AFPR. I got mine from Summit for a little over $100. I cant remember the part number, but it's the one that goes from 25-60 PSI. But, then you'll need something to raise pressure( FMU) back up in boost if you drop the base pressure to much. If you dont wanna go the mechanical fuel system route, you could get Megasquirt, Emanage, etc and go stand alone(which is the best way to go for those who get really serious)
Failure is not failure if you learn from it
Tuesday, February 28, 2006 9:10 PM
I think 2200 uses side feed injectors :S
Tuesday, February 28, 2006 9:17 PM
Get an FPR that's made out of carbon fiber & kevlar. That's the best kind.
-Chris-
-Sweetness-
-Turbocharged-
Wednesday, March 01, 2006 12:31 PM
ge_forcez22 wrote:I think 2200 uses side feed injectors :S
no, it doesn't...... top feed for the 2200....... side feed for the 2.2 like 97 and under I think. (not sure of the year change)
Top feed for the 2200 though.
Lee
JDM Civic Hatch
Wednesday, March 01, 2006 12:47 PM
Lee
yep you're right Lee, 97 and older 2.2s have the side feed, my 98 was the first year of the 2200
http://www.cardomain.com/id/oyyci
http://photobucket.com/albums/d170/Oyyci/
Wednesday, March 01, 2006 1:04 PM
^^^^^^ your lucky if you want to boost it then !!!! woot !!
Lee
JDM Civic Hatch
Wednesday, March 01, 2006 4:24 PM
BoostedCavi wrote:^^^^^^ your lucky if you want to boost it then !!!! woot !!
Lee
who doesn't? i do though, i am sniffing around parts as we speak
