how to install injectors - Boost Forum
Monday, February 27, 2006 3:56 PM
i have injectors from a turbo coupe thunderbird. i have the turboed 99 z24, how do i do the wires? which ones go where? what colors connect to what? please give me info i wanna hook these up!! thanks
Re: how to install injectors
Monday, February 27, 2006 5:19 PM
WIres it doesnt matter which one goes to which...there universal. Make sure there not the brown tops (the color of the injector is brown) becuase those are low impedence injectors and you need high impedence. Use the plugs that were on the T-bird if you can get them and splice (solder) them in to your harness on the cav.
Monday, February 27, 2006 5:43 PM
they are the brown tops. i was told they will work was he wrong?
Monday, February 27, 2006 6:23 PM
There low impedence....your car uses high. It wont work unless you put a in-line resistor or somthing like that to convert your's to low mpedence...search the forum, Theres a post on how to do it i beleve somewhere around here.
