Charge Pipes and Downpipe - Boost Forum
Monday, February 20, 2006 10:00 AM
does anyone know of a site where i can buy just the charge pipes and downpipe for an ecotec.
i dont have welding skills so im kinda stuck paying someone to do it either way and that would just be easier
Re: Charge Pipes and Downpipe
Monday, February 20, 2006 10:48 AM
the piping is different depending on the Turbo, Manifold, Intercooler you choose. They are not universal.
what are you using for those 3 items?
"Growing old is mandatory. Growing up? Definitely optional."
Monday, February 20, 2006 11:01 AM
well im looking to pick up a t3 turbo
for a manifold im using a custom made one (ill try and get pics)
and im not using an intercooler at this time
Monday, February 20, 2006 11:04 AM
you will have to bring you car to someone most likely then.
I would do it for you but I am VERY far away from you.
Monday, February 20, 2006 11:06 AM
alright well what kind of prices would be appropriate so i know the range before i start asking?
Monday, February 20, 2006 11:34 AM
Do what im going to do and buy a u-j mandrel bend and some straight pieces and some couplers and piece it all together yourself. All tubing is going to be different for each car. It all depends on where you want to run it(underneath the car or through the engine bay) If your going to run it underneath you will want to use 2" pipe because there isnt alot of space to put it underneath.
Monday, February 20, 2006 1:59 PM
ok i know this is going to sound retarded
but after you piece it 2gether with duct tape or w/e then what?
just take it out and get it welded??
Monday, February 20, 2006 2:11 PM
Pretty much
You can either take it to get welded or use couplers to hold it together but if i were you take it to get welded but only get welded what you can get out meaning dont get the whole system welded as one piece cause you'll never get it back on the car. Heres an example. This is a 2.4L, not an ecotec but notice how the pipes are connected.
Monday, February 20, 2006 2:49 PM
so your not going to get any pieces welded at all?
seems like overtime couplers would leak wouldnt they?
Monday, February 20, 2006 2:51 PM
Im going to make sure i have atleast one or two couplers on each set of pipes just for some play so the welds wont crack .
Monday, February 20, 2006 2:57 PM
blue splash: are those 2" or 2.5" charge pipes?
does anyone have any pictures of any different way to run the charge pipes?
Monday, February 20, 2006 4:00 PM
Putting together a downpipe piece by piece isn't a bad idea. Mike Karas created my 3" downpipe.
Monday, February 20, 2006 4:25 PM
My downpipe was made from 2 seperate pieces of 2.5 inch mandrel bend pipe. The size in the picture shown about is from a member on j-body BOOSTED2POINT4. I believe they are 2.25" or 2.5". IM going to be using 2" for quciker spooling and because it is tight underneath the engine.
Monday, February 20, 2006 9:39 PM
Hey blue splash not to get off topic or anything but do you have any motor shots and what turbo accesories he's running on that setup? I am in the process of working on my charge pipes and I actually had my plans drawn out just like his are being run. Thanks in advance!
~Boost. Its what's for dinner!~
Tuesday, February 21, 2006 6:31 AM
Heres his cardomain page....boosted2point4
Tuesday, February 21, 2006 7:09 AM
Sweet! Those were exactly the pictures I was wanting to see. By the looks of things I should be able to have the cavalier turbo just in time for the drag strip to open up. Thanks for your help/
