after cat 02 sensors are for suckers - Boost Forum
Friday, February 17, 2006 7:25 AM
If im running my standalone with injector control then Its not going to matter about my after cat 02 Right? it will throw a code but all that will do is try to flood the injectors (which obviosuly wont work) my real question is will it screw with timing or spark? I dont think so I havent heard of it at least but figured I ask before I go and do something stupid like put my turbo on.
"Kick azz is my boost hero!!! "
Re: after cat 02 sensors are for suckers
Friday, February 17, 2006 8:27 AM
the after cat 02 sensor don't do anything else than monitor the cat ativity. It won't flood or do anything if you get a code.
Even the first 02 sensor unplug will not flood the engine because the Ecm will run with the preset data.
Gilles
2.3 Ho
Friday, February 17, 2006 9:28 AM
thanks
Friday, February 17, 2006 3:21 PM
yes the 2nd o2 just monitors the temp of gases coming out of the cat to determine its functionality. apparently there is a simulator you can plug into the harness to simulate the 2nd o2 sensor working.
Saturday, February 18, 2006 1:56 PM
^^^ The O2 simulator, yes--and it works like a charm. I've had it in for about 2 years now.
