Oil pressure sensor location for turbo feed - Boost Forum
Sunday, February 05, 2006 10:35 AM
Hi, where is the oil pressure sensor on a 2001 2.4L ?
I want to know the location of the sensor so I can install oil feed line for turbo.
Do you remove the sensor when installing the feed line? I have some difficulty figuring out the oil feed thing.
Thanks!
Re: Oil pressure sensor location for turbo feed
Sunday, February 05, 2006 10:38 AM
Its right in between the two cam towers, under the IDI connector. A lot of people just remove the sensor completely, since its just an oil pressure switch that turns on during low oil pressure situations. You can either get rid of it, or use a T fitting to put the feed and the sensor there.
