P0300 Code Please Help! - Boost Forum
Friday, February 03, 2006 5:15 AM
i have been having this problem. at cruiseing speed it will misfire and sputter but if i put my foot into the gas this problem will go away until i am back at part throttle. i have gone through 3 different types of plugs.....stock, ngk tr6's, and now stock SRT-4 plugs. all have had this problem but i have noticed that once this situation starts if i am going down the road and i leave the car in gear with the clutch out and turn the car off and then back on at a roll this problem goes away until i turn the car off? WTF???
i'm thinking that it could be my map sensor or my TPS going out but i'm not sure. I have heard of some people with the 03 ecotec having this problem due to bad injectors and o2 sensors but i am clueless so i'm asking the ORG for help.
2.2 L Ecotec, P&P Head, Stage 3 Comp Cams, Supertech 76 lb Spring kit, Supertech Oversized Valves, Wiseco 8.9:1 CR Pistons, Eagle H-Beam Rods, Home-Built Turbo Kit T3/T4 57 Trim Intercooled, 78 lb/hr Racetronix Hi-Z injectors, Aeromotive FPR, Racetronix f body fuel pump,MEGASQUIRT MS3 + MS3X Finally street tuned on 21 lbs! Now if only I could get it to hook....
Re: P0300 Code Please Help!
Friday, February 03, 2006 7:42 AM
are you running an MSD ignition??
Friday, February 03, 2006 7:47 AM
yes i am
I bypassed the MSD and the problem was still present
so i'm thinking maybe the stock Ignition Control Module could be going out but i want to be sure before i go buying one of those.
Friday, February 03, 2006 7:49 AM
have you been running a big gap on your plugs??
.040 on the SRT-4 plugs
Friday, February 03, 2006 9:21 AM
wish i could help more but i'm not to up on my Eco stuff.
Friday, February 03, 2006 3:31 PM
this code comes up when you run an msd without the 8914 part or its hooked up incorrectly. It is camshaft postion, the eco doesnt use a sensor for camshaft position it detects when the 4th cylinder is firing and then the ecu reads that, when you hook up the msd your bypassing that and if you dont use the camsync generator part you will get the code
Here
Friday, February 03, 2006 3:36 PM
damn now that's very interesting. so it generates the signal that the 4th cylinder is firing??
Friday, February 03, 2006 3:40 PM
it detects when #4 is firing for the cam signal that signal is sent off the icm on the brown/white wire back to the PCM
Tuesday, February 07, 2006 6:00 AM
ok problem solved i was running the cam sync generator but the sensor wire that wraps aroung the #4 boot had slipped up toward the idi cover and away from the plug and spring. moved it down and zip tied it and all is gravy now. Thanks a bunch guys!
Tuesday, February 07, 2006 2:18 PM
actually i didnt read this right 0300 is a misfire 0340 is the cam thing, but since you were talking about hte msd i assumed the 340 code
Tuesday, February 07, 2006 3:28 PM
Rodimus, is that 8914 the correct PN for the cam sync generator? This is a recurring question our customers have, you seem to be up on it. Thanks!
Bill Hahn Jr.
Hahn RaceCraft
World's Quickest and Fastest Street J-Bodies
Turbocharging GM FWD's since 1988
www.turbosystem.com
Thursday, February 09, 2006 7:28 AM
yes bill 8914 is the correct cam sync box
thank god that MSD even put a troubleshooting LED on the box!
