do u install these the same way u install the S-AFC 2 thanks
does any one know the answer to this
Yes, the SAFC-2 and SAFC install the same.
ptv177 wrote:thanks alot
You're welcome
FYI: The only difference between the two is that the 1st SAFC has less options than the 2nd one and the interface is different.
but i can still use it for my turbo right, and eventually will i have to upgrade to the safc-2
only difference is that the safc2 has a knock sensor
ptv177 wrote:but i can still use it for my turbo right, and eventually will i have to upgrade to the safc-2
I wouldn't suggest an SAFC for a turbo setup. An SAFC allows you to tune per RPM not per Boost...it's not something that is real efficient for a boosted application. Look into either an Cartech adjustable FMU or a Standalone.
SAFC is the worst possible method to tune for boost. Either FMU / AFPR or standalone.
how about a safc2 and a wideband would that work ok
.....it would work but like stated above, it's not the best method for boost tuning.
