GM supercharger - Boost Forum
GM supercharger
Saturday, January 21, 2006 10:07 PM
alright ive bee searching for a couple hours now, and ive read hazenriders write up on putting a S/C on a pre 2000 car, im pretty clear on everything that has to be done, except for the computer issues,
i read that if i dont want to swap computers then i would have to upgrade the injectors, a FMU, better flowing fuel pump, and then i should be alright
as i see it rite now, to make this work, i will need
2000 starter cuz its smaller
injectors
FMU
better flowing fuel pump, is a walbro 255 lph to much?
EGR block off plate
is the higher temp thermostat necessary?
nething else i should know b4 i go through with saving the money and such for the install, im still reading on it, but maybe a few pointers from the guys with this done on a pre 2000 car, id like to avoid messing with the computer if possible, thanks
Re: GM supercharger
Sunday, January 22, 2006 11:02 AM
dont monkey with the thermostat.
my set up is in my registry and has been working over a year.
i tried many set ups, and the one u see listed is by far the best. i am on the stock injectors, FMU, and 255 fuel pump. but that is the stock s/c pulley.
only problem is you will have to clear a EGR code each time u start up the car(if u dont have a 99).
egr simulators are out there, but cause issues with map voltage.
Re: GM supercharger
Sunday, January 22, 2006 1:23 PM
so it would work other then getting a code each time? any problems from not having the egr i should know about? thanks
Re: GM supercharger
Sunday, January 22, 2006 4:34 PM
nope, been running egr less for a year. no problems. i get 30ish miles per gallon too.
just that stupid code. but it takes me 30 seconds to clear it when the car starts up. sorta annoying but better then a stalling,hesitating and rough running car with a egr simulator hooked up.
Re: GM supercharger
Monday, January 23, 2006 5:41 AM
... or do the 99 reflash.
Chris
'02 Z-24 Supercharged
