which wire is the one I splice for the ifniton wire for a push button starter. and where is the simplest place to accesse it.
boobs now with Riboflabin"
To get access to the wire you need to get the cover off of the steering column. The one where the hazzard flasher sticks out. There are three bolts on the bottom of the cover I think they are 8mm. Take them out and pull apart the cover, the cover is two pieces held together with clips (you can pull off the top before if you want). The wire you are looking for can be yellow or brown in color depending on the year of your car. Newer ones have a yellow wire running to the ignition key cylinder. The wire is attachted right to the ignition key cylinder. Just unplug your battery before you splice it. This is the simplest way to get at the wire and you can route the wiring to anywhere on the I/P.
My Sunbird.... Still has some attitude
Oh yeah you gotta disable passlock before you can use a push button start other than that I really don't know too much else on doing a custom start button on a J.
Good luck
thank god I have posted this Q before with no reply. also I thought that you didn't need to worry about the pass lock as long as you have the key in.
If your gonna keep the key in then no worries.
Anyone else care to fill in on this question?
I am sure someone has done this before, I may want to in the future.
well I found out whats going on but now IM trying to figure out if I should bother spliceing the wire any ware else in the car. also is it hard to pry off the cig lighter and if that is sending a 12V charge can I use it for the push button starter.
How bout this..
Remote Starter...
Hack the remote and hook up your button to that.
just a thought.
AHHHH sutpid thing wont work
Ive tried all three wires that come out of the key hole and not a single one works. Doesn't any know how this damn thing is supposed to work. I apprciate the help so far but it seems hopeless
You'll have to test it to find which one is the starter wire...
<img src=http://www.consumptionjunction.com/i/default03.gif>
I have tried testing them the Q is, is
A: am I trying the right ones. because none seem to do any thing
B: Is a push buttons job to just connect a 12V to a Start wire?
HELP!
If your test light isn't broken- and you have it properly grounded...
When you are probing the starter wire- it won't do anything until you crank the motor... The starter wire in your vehicle is yellow..
All the push button does it throw 12 volts to the starter-- If the key is not in the ignition, and you didnt bypass passlock is anyway, the car will turn over- then die right away.
Your key will have to be in the ign for it to work- which is why I dont understand why anyone would want it.
BTW- you live in K.O.P? I live right down the bottom of 476...
I posted it in anoter thread the button is part of my senior project. if what you say is true and all I need to do is throw 12V to the yellow wire then the damn thing should have started!!!! hmmm ill have to keep tinkering mabye I didint give a good connection.
Also Thats crazy that you live so close you should stop by some time and check out the car it would be good to finnaly meet some Jbo tuners theres only one other guy I know of around here and he buoght his CAV pre done and dosent know ish about cars.
