4x6 or 4'' ROUND??? wut else can go in front door - Audio & Electronics Forum
Tuesday, April 26, 2005 12:20 AM
hey i was thinking about getting the 4'' round adapters for the front? wut is the different between 4x6 speakers and 4'' round speakers? advantages disadvantages? which one would sound better ect..?? let me know thanx
Re: 4x6 or 4'' ROUND??? wut else can go in front d
Tuesday, April 26, 2005 12:21 AM
i meant 6 1/2 ROUND front ones sorry... which would be better 6 1/2 round or 4x6
Tuesday, April 26, 2005 2:48 AM
the 6.5"s will be better.
true.
Cannon fodder is my daddy.
Tuesday, April 26, 2005 5:33 AM
really depends on the quality of the speaker, 4x6 are generally made for drop in applications, wherea as some 6 1/2" are built that way too. but if your going 6.5's go with a componet set, that will usually give you your best sound
Tuesday, April 26, 2005 6:41 AM
Sticky: Speaker Size Info(CLICK BEFORE YOU POST)
Should give you some more info on mounting
<img src=http://www.mclonedogmcwad.com/sig3.jpg>
Please visit <a href="http://www.mclonedogmcwad.com">mclonedogmcwad.com</a>
Tuesday, April 26, 2005 8:02 AM
wuts the difference of a componet set vs something else??.. and wuts a good componet set? please let me know thanx
Tuesday, April 26, 2005 8:57 AM
first off it's what is? no wuts
Componet sets give you a more clean and direct sound, you would have a woofer or midrange speaker aka the 6.5 and then a tweeter mounted close in proximity to this speaker. Also freq's can be separted using a crossover (usually suppied) to allow better sound
If you have a full range speaker such as two way or three way speaker, the sound is not as clean.
Good brands for componets set:
Infinity
Polk
MB Quart
If you have the money try and find a good componet set if not you can get a good two way speaker that will sound ahella better then factory.
Wednesday, April 27, 2005 6:04 PM
if you want to use the stock bracket and just mod it a little bit and not have to build a seperate bracket to house bigger speakers (not trying to sound lazy....just being practical if you dont have the extra money for materials or care about what size your front stage is) Pick up a set of the polk 4x6 plates or the infinity plates. I have the polks and both have a 4" round driver and a seperate tweeter on the same plate and the polks i have sound pretty dang good powered off my premier deck for now. they should sound better with a good amp.
Wednesday, April 27, 2005 7:11 PM
if you use one of the adapter plates, or create your own for larger speakers in the front doors, is there any problem with the speaker rubbing the back of the door panel once installed? it just seems if you add an extra half or 3/4 inch to the space in front of the factory hole, it would be very close to the door
Wednesday, April 27, 2005 8:19 PM
Stay away from plates they dont sound as good as a coaxial set. But sndsgood is right as always the best way by far is to get a good component set. Infinity makes good component sets and kicker just came out with some new ones that sound amazing. the kickers are a little pricey but sound really good.
Wednesday, April 27, 2005 9:11 PM
Mine are close but I have about 1/4 inch of room between my woofer and the back of the door.. that's plenty of space. I doubt that 6.5 has that much excursion lol
