i have 4 DVC 4 ohm subs. i want to get atleast 1500 watts to them at 4 ohms. now if i wire them in a parralel series it will bring a 2 ohm load. and if i wire them in series it will be a 4 ohm load correct?.
second question is this amp states that it is 1500 at 4 ohms. now i realise that is rms. which is what i am looking for actually. but is it possible to run the amp at 2 ohms bridges with a parralel series. or can that amp not handle that?
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=18796&item=5769859608&rd=1
any help is apreciated
4ohm mono is all your gonna get. personally i would use a more effecient class D amp for your subs...
you can wire your subs up 2 ohm mono or 0.5 ohm mono
1ohm stereo, or 4 ohm stereo.
find an amp that does it's rated power at 2 ohms.
here's my suggestion...
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=64573&item=5769668072&rd=1
without knowing what subs you have and the power ratings for them, can't recommend much.
SOUNDSTREAM
DB LINK
DB DRIVE
PANASONIC
GARMIN
ROSEN
SCOSCHE
XE DESIGNS
SOUNDGATE
PAC
LITEGLOW
the only amp to relly help you is a jl audio 1500 watt amp its 1500 and all the amp runs is 4ohm no matter what ohm u got the subs wired think like this it's like you pay
67 cents per watt price really shows a difference in car stero
Yeah...we kinda need to know what subs you have. But otherwise...
You can wire your 4ohm DVC subs to that amp in two channel mods. Wire them in series...1 sub per channel and you'll get a 2 ohm load....or 800 watts per sub (or so the ad states). The amp is 2 ohm stable in 2 chanel mods. Thats pretty much the only way to wires DVC 4 ohm subs to that amp.
oops....i didn't realize you had 4 subs....my reply was for 2 subs. Dont listen to me
sycx 1 A.K.A snoop wrote:the only amp to relly help you is a jl audio 1500 watt amp its 1500 and all the amp runs is 4ohm no matter what ohm u got the subs wired think like this it's like you pay
and WHAT amp is that again??
SOUNDSTREAM
DB LINK
DB DRIVE
PANASONIC
GARMIN
ROSEN
SCOSCHE
XE DESIGNS
SOUNDGATE
PAC
LITEGLOW
^ yeah...I'dike to know also.
