Upgrading alt - wiring to starter also? - Audio & Electronics Forum
Tuesday, April 19, 2005 6:14 PM
Okay, I've done a bit of research on the Big 3...
But is it necessary to run the same "path" as the stock wires from the Alt to the Starter to the Battery?
(I have a 95 2.2, btw.)
If it is NOT necessary to follow that path, can I dissconnect the "starter to the battery" since the alt will go direct?
(I am also going to do the alt to ground and battery to ground. I am using 4 gauge stranded...)
Any help would be much appreciated!
L8r...
___________
. . . . jb . . . .
...Son Fire!
*** Need some 1995 Cavalier parts ???
*** FOR SALE: doors, windows, interior, engine parts, fenders, etc. -- email me
Re: Upgrading alt - wiring to starter also?
Tuesday, April 19, 2005 6:21 PM
no need to bother with the starter...just run it straight to the battery and leave the stock wires alone.
SOUNDSTREAM
DB LINK
DB DRIVE
PANASONIC
GARMIN
ROSEN
SCOSCHE
XE DESIGNS
SOUNDGATE
PAC
LITEGLOW
Tuesday, April 19, 2005 6:25 PM
Should I keep the stock wires hooked up: alt to starter and starter to battery as well as using the new 4 ga. wire direct from alt to battery?
I read a post where you mentioned that you kept the stock wires in place (in case you ever would sell the car -- good idea, btw -- but I wasn't sure if you dissconnected them, too....
My alt is top left of the engine compartment (by the overflow tank) and I guess I'll run the positive wire along the front (and top) of the fan cover...
Thanks, btw!
L8r...
___________
. . . . jb . . . .
...Son Fire!
Tuesday, April 19, 2005 6:31 PM
yea...it won't matter if you leave the stock wires or not..the current will travel the path with the least resistance (the bigger wire most likely)...you can simply add your 3 wires and that's it.
SOUNDSTREAM
DB LINK
DB DRIVE
PANASONIC
GARMIN
ROSEN
SCOSCHE
XE DESIGNS
SOUNDGATE
PAC
LITEGLOW
Tuesday, April 19, 2005 8:54 PM
Very cool. Thanks a lot for your help!
Any ideas on how to remove the pulley from the alternator? That biatch will NOT come off! LOL
L8r...
___________
. . . . jb . . . .
...Son Fire!
Tuesday, April 19, 2005 9:01 PM
dunno..never done it!! lol.
SOUNDSTREAM
DB LINK
DB DRIVE
PANASONIC
GARMIN
ROSEN
SCOSCHE
XE DESIGNS
SOUNDGATE
PAC
LITEGLOW
Tuesday, April 19, 2005 9:05 PM
Thanks anyhow. I'm gonna let some WD40 soak in there overnight, I guess...
L8r...
___________
. . . . jb . . . .
...Son Fire!
Wednesday, April 20, 2005 1:54 PM
why do you need the pulley off?
____________________
84 Fiero
Wednesday, April 20, 2005 2:57 PM
I have a set of power pulleys (undersized) and one goes on the alt. I have to transfer it from the stock alt to the hi-output... It's being stubborn!
I have one more idea to try before I really get ticked, tho. LOL
L8r...
___________
. . . . jb . . . .
...Son Fire!
Wednesday, April 20, 2005 5:29 PM
The only way i could get the pulley off the alt when i changed the alt in my van was with an impact gun at my shop.
Wednesday, April 20, 2005 8:59 PM
I got it off tonight using a 24mm box wrench, E10 (size?) male star socket, a ratchet, a pipe, the old belt and a vice... I also soaked it overnight with WD40.
Worked like a charm -- don't know why I didn't think of that earlier... Praise the Lord for pipes that "extend" the ratchet handle! LOL
Thanks for the help guys!
L8r...
___________
. . . . jb . . . .
...Son Fire!
