ok ok, don't be harsh, lol. and yes i tried the search. i just wanted to know if you guys had any good links that show how to wire up subs + amp + capacitor. i'm thinking about trying it this weekend. thanks guys!
"hard work pays off... why the hell doesn't it pay off for me?"
That'll get you the subs. As for the amp and cap, you need to make sure you charge the cap before installation. There should be instructions with the cap on how to do this, along with the appropriate resistor to charge it at the correct rate. If you can't find the instrux for the cap, check the manufacturer's site, many have a tech center that will have that info for you. After the initial charge, you need to take the + from your battery, connect it to the + on the cap then the + on the amp. Do the same for the -. Make sure you use the same size wire (i.e. 4 gauge) from the battery to the cap to the amp on both the + and the -.
