neon lights problem - Audio & Electronics Forum
neon lights problem
Monday, April 11, 2005 12:18 PM
I'm trying to wire my interior neon lights and my instrument panal to come on when I open my door. I found the wire that puts my instrument panal on but I don't know were to look for the one that puts my dome light on when I open my door. Where should I look for that?
Re: neon lights problem
Monday, April 11, 2005 12:30 PM
a dictionary?
Monday, April 11, 2005 12:39 PM
a dictionary?
Monday, April 11, 2005 8:32 PM
my dome light comes on when i open my door... start there.
<IMG SRC="http://registry.gmenthusiast.com/images/neo32843/personal_pic.gif">
<A HREF="http://www.sandstorm-j.741.com" TARGET="_blank">Pictures and More</A>
<A HREF="http://www.crush007.com/love.cgi?id=1112583099dpm" TARGET="_blank">Love And Sex Life Prediction</A>
Tuesday, April 12, 2005 5:22 PM
just put em on a toggle switch and let them run thats what i do
Tuesday, April 12, 2005 5:30 PM
That's what I have ryt now. I just got this idea this weekend and i'd like to make it happen. I have not done nothing yet. I wanted to take a look yesterday but it was freezing outside
Tuesday, April 12, 2005 5:32 PM
you wanna go under the dash, basically if there is a panel underneath take it off. Then go on the internet get the wiring codes for a cavalier/sunfire whichever you have, i doubt they change between them. Then find the right wire that controls the domelight output, splice into it. Better to take some of the wire off by stripping it then wrap the other wire around it and preferably sauder them together if you cant sauder then electrical tape them. If you can sauder them though it is highly recommended.
Tuesday, April 12, 2005 5:36 PM
where do you go on the net for the wiring codes?
Tuesday, April 12, 2005 7:47 PM
I found my wires for the dome light on the a pillar on the drivers side and spliced into them to run my Neon relay, I had to run the hot and the ground off of it to work though, and with the dome light staying on after the door is closed it looks cool when you walk away and it goes out....I did have to put a switch on the light so it wouldn't turn on when the neon were on, and I had the neons on a switch so I could turn them off too....
I could run the neons by opening the door with the dome light on
neons by the door with the dome light off
neons by the headlight thingy (twist to turn on interior lights, 90 cav)
and then I could run the Dome light with the door and the neons off
and the dome light by the headlight knob.
if your lost, Ask and I can try to explain better.
Good luck.
Everything LOUDER than everything else!!
Wednesday, April 13, 2005 5:24 PM
I found the wires on the pillar and went there with a test light and could not find any juice in the wires. I'll try to think of something else before the weekend.
Wednesday, April 13, 2005 5:27 PM
If your dome light was on, and your test light wasnt.... Test your test light and try again...
Wednesday, April 13, 2005 5:32 PM
I did...Don't know whats going on???
Wednesday, April 13, 2005 9:00 PM
Ok, If you wanna make this easy, do this. Make a friend at an install shop, one where they do alarms. Get them to either print you a tech sheet, or tell you which wire is your door pin trigger, and where to find it. Assuming this is a positive trigger (I haven't checked), use it as your power for the lights, if it is negative, buy a relay and set it up.
______________________________________
Hell hath no fury like a pissed off balloon animal.
"Sup, G?"
"Aren't you white?"
"Only on the outside, craka."
Thursday, April 14, 2005 8:58 AM
find the door pin in the door, this is how the light turns on. open the door, the pin closes the circuit and grounds the wire and the light comes on. its up front by the kickpanel. there are two wires that go to the pinswitch in the door. youlle have to try both, one is a slow drain and the other one is an immeditate on and off, u want this one. run your ground from the neon to that wire, now, youlle also need to put another ground to the wire from the pinswitch on the passenger door, that way no matter what door u open, your neons will come on. this is how i originally had my neons wired up. i never cared to drive around with the neons on.
