well, that amp doesn't list that it would be 1 ohm stable, so you would have to wire your sub in series
+ from amp, to + on one coil. - on that coil, to the + on the other side. - on the second side, to the - on the amp.
That'd be the way to go with those two.
or u can run 1 coil to 1 channel on the amp
you will need to wire the sub in series to bring teh load up to 4ohms that should be safe for the amp
Greg R wrote:haahahahah LANZAR.
wow yet another dumb newb
Dunno if I'd say that....he's just not seen what Lanzar can do when installed correctly...
