Whats the deal? Anyone ever had this happen to them before? They just stopped working.
You either blew the speaker, there's a loose connection, or a channel went in your head unit. Check the connections first.
Beat it like it owes you money
Both the left speakers stopped working, and I know I didnt blow them. Any other possibilties? They are wired via the stock wiring harness...
what happened when they stopped working?
check connections at the speaker, and at the back of the deck.
also hook up another speaker that you know works to the wiring...if the test speaker works, then you know it's a problem with the speakers. if it doesn't work. then it's a problem with the wiring.
SOUNDSTREAM
DB LINK
DB DRIVE
PANASONIC
GARMIN
ROSEN
SCOSCHE
XE DESIGNS
SOUNDGATE
PAC
LITEGLOW
i fixed it, the connectors where knocked off
the most obvious thing...and the thing you should have checked before even asking. good job
SOUNDSTREAM
DB LINK
DB DRIVE
PANASONIC
GARMIN
ROSEN
SCOSCHE
XE DESIGNS
SOUNDGATE
PAC
LITEGLOW
