im trying to find a place to ground the neons under my dash, but i dont see a good place to put it. could someone tell me or perhaps, show me a good place to ground by neons?
thanx in advance
* * BIG FOR SALE POST * *
Either run a wire to your battery or look around in your car for a good ground (by the door,ashtray) should work. Just make sure if there is any paint to scrape it off or it wont be a good ground
*95 Z28 M6* *Free mods* *160 t-stat*New LT1 Crate motor 357*Edelbrock Headers*3" Flowmaster cat back* !CAT
under the driver side port, use one of its screws. perfecr ground for me.
Fact 1:
true.
Obviously in the ground you idiot.. So get a big metal stake and pound it into the ground
____________________
84 Fiero Its a semi stock. ( i just made that up) woohoo
you can get a distribution block and mount it under the hood and hook a 8 ga to the frams and run as many ground wires that you want that is what i did
Fast isn't always good, looks and sound is sometimes better
Imamarine
You should always make your ground as short as possible.I would suggest two small self taping metal screws and screw them into your metal dash board frame (outta site) and if you have a mutlimeter check your ground.
Friends Don't Let Friends Drive Stock!!!!!
