k so i was about to start brown breading my car when noticed the oddest thing air vents in under the carpet, im sure these cause rattle on the extrior and seeing as im now lookign for what i shoudl do to seal them up, lol, i know i rea dboutt hem beofr ebut i thoguht maybe they were the older cars, but lol, btu anyays giev me some idea sother than welding cuz i odnt wanna weld it shut
Just remove it and but some brown bread over it.
"all your bass are belong to us"
those vents are there so that ur trunk doesnt create a vacuum/pressure when u open and close it
![](http://registry.gmenthusiast.com/images/machzel08/sig.JPG)
"Official Jewish J-Body"
yes, they are for cabin pressure. I just put duct tape over mine. they flapped like crazy. really annoying too. Be careful when taping it up, if you don't seal it water can get in and seep down into your spare tire well.
SOUNDSTREAM
DB LINK
DB DRIVE
PANASONIC
GARMIN
ROSEN
SCOSCHE
XE DESIGNS
SOUNDGATE
PAC
LITEGLOW
sorry not to jack the post or anything, but I am having the problem of water seeping into my spare tire well! How can this be fixed and is it comming from the vents?
it's probably coming from your trunk lid not being aligned properly. If you have a sunfire they are notorious for not sealing up correctly. I dont know about the cavaliers but i imagine its the same case. What you should do is crawl into your trunk through the backseat during daylight and see if you can see any light coming in around the trunk lid, that will tell you it is not sealing properly. I had to work on mine for quite a few hours to get it to sit properly and my sister's still will not seal properly.
As for the vent , i also just sealed mine up with some dynamat, brownbread or whatever you wanna use. It is also to help moisture escape from the trunk, but as long as your trunk lid is sealed properly it should be ok to cover this up.
where exactly are these vents in a cavy?
______________________________________
Hell hath no fury like a pissed off balloon animal.
"Sup, G?"
"Aren't you white?"
"Only on the outside, craka."
Bloodspiller wrote:where exactly are these vents in a cavy?
right hand side, in rear corner under the carpet. you can see it if you look up under the quarter panel behind the tire also.
SOUNDSTREAM
DB LINK
DB DRIVE
PANASONIC
GARMIN
ROSEN
SCOSCHE
XE DESIGNS
SOUNDGATE
PAC
LITEGLOW
is there one one the left hand side or no??? or is it just one vent. oh by the way it rattles like a mofo when i crank the bass along with all of the trunk panels lol......
![](http://img169.exs.cx/img169/6163/mycarimage8to.jpg)
!!!jbody Customs!!! yo hit me up if you need anything!
streetfire2006
just the passenger side.
SOUNDSTREAM
DB LINK
DB DRIVE
PANASONIC
GARMIN
ROSEN
SCOSCHE
XE DESIGNS
SOUNDGATE
PAC
LITEGLOW
i put dynamat on mine. no more flapping!! it was soooooooooo annoying!!
Peace Out!!!
