ok now i didnt know where to put this but it does deal with electronics. i am wondering where i would relocate my ecm or pcm or whichever it is that has to be relocated for the strut bars. im not needing it for the strut bar but i am trying to relocate all the wiring and get it to be as basic of an engine bay as possible. eventually i will get crazy with the engine bay but right now im just trying to simplify it. if anybody has info as to how i could relocate it i would appreciate it. thanks in advance.
dude ok somebody had to of done this to install a strut bar or something. even if it may be useless to me right now id still like to simplify my engine bay. not to mention it will make it easier when it comes to washing the engine bay as i wont have to worry about the electronics getting wet and shorting out.
ok so i take it NOOOO body on the org has relocated their PCM or ECM when installing a strut tower bar? well i dunno. how hard would it be to relocate it? i could just extend the wires to it right? well if anybody can at least tell me that answer then that would be great. thanks for any info...
1. Remove the bracket from the ECU.
2. Unplug ecu.
3. Pull wires through existing hole in the firewall.
4. Plug ecu back in.
5. Stuff ECU under the dash.
ok thank you.... thats all i wanted to know i hadnt done anything like that and i didnt think it was as simple as that i figured id have to keep it in the engine bay unless i lengthened the wires.... anyways thanks man appreciate it.
does anyone know if they make ecm extensions to move the ecm inside the cab or do I have to extend each wire. Any information is greatly app
LIVID wrote:1. Remove the bracket from the ECU.
2. Unplug ecu.
Just how far would you move it to need an extension?
On my 03 the wires were long enough to move the ECU/PCM/whatever you want to call it, to under the wiper cowl.
![](http://imageshack.us/a/img51/1489/6vkp.jpg)
