I currently have a cheap system (walmart special if you know what im saying). I am looking at doing a huge upgrade. I want to run 2x 12" Skar VVX 12v2. I will do a ported box with subs and port facing front window. My question is how well do these perform and what amp should I run. Looking to do about 2ohm.
Speakers:
Skar VVX 12v2...
Looking to pay no more then $300 for new amp any ideas?
Ok I am guessing no knows or no one wants to answer. Well I will figure it out, thx anyways.
check out autotek and hifonics amps. they're the same amps internally but the autoteks are cheaper. i got my 2000watt rms mm4000.1 on ebay for $135. and face the subs and port to the trunk. will be much much louder. also, if you're gonna pay $200 a sub don't get skars. get two sundown sa12's they're the same price and can actually handle well over 1000rms clean power.
Also we need more information to give you a good recommendation. What is the rated RMS wattage of one sub? Dual voice coil? Single? 8ohm, 4ohm, 2ohm? Usually when we tell someone what to buy they get mad because it's too expensive. So the problem is no one wants to tell you to go buy a crappy amplifier for cheap and no one wants to tell you to spend more money than you probably want to spend.
"In Oldskool we trust"
also if i were you id get two DVC 4ohm subs and wire them to one ohm. why run 2 ohms? you're just restricting how much power the amp can put out and making it put out distortion because you have to turn the gain up higher. both amps i recommended are 1 ohm stable and are most efficient at 1 ohm.
Thanks all I got (2) Skar VVX12v2 dual 4 ohm and wired then to 1ohm. I got the Hifonics BRX 2400.1D amp 1ohm stable. I faced then into the car because of ported box. These things are loud and hit hard. Im not going to try to turn the box due to me having to take trunk hinges off to get box in.
i have a ported box and one that is much bigger than yours should be. with 2 12s you should be able to just take the box in and out of the trunk. you have too big of a box for them if you have to take the hinges off man. haha i still think you shoulda gotten sundowns for that price but to each his own! got any pictures of what it looks like?
heres mine. haha
- Attachments
- IMG_20140310_101653.jpg (1091k)
