Turn signal wiring - Audio & Electronics Forum
Turn signal wiring
Tuesday, January 22, 2013 7:50 PM
Hello I was curious if anyone has a schematic or an idea where to connect turn signals from a mirror into? I'm going to be purchasing Ferrari F430 exact replica mirrors with built in led arrows and front light. Now I've never wired something like this before so any help would be greatly appreciated.
Re: Turn signal wiring
Thursday, January 24, 2013 6:50 PM
Wire it inline with the front turn signals
Thursday, January 24, 2013 7:21 PM
Or relay it so it flashes opposite to the turn signal like most new cars. turn signal flashes then mirror.
<img src="http://www.v6z24.com/jbodyforum/images/signatures/cavalier3400z.jpg" width="319" height="199"/>
Thursday, February 07, 2013 7:02 AM
ok so i recieved the mirrors finally, problem is how am i to hook them up if the turn signals are on most of the time as running lights? when the car is on and the headlgiths aren't on all the way they are running lights and both bulbs in the front assembly light up, when you use the turn signal one light blinks and when you stop using the turn signal it goes back to solid on, when the headlights are on the two bulbs in the assembly blink sequentially. is it possible to delete the drl or modify it to accept the mirrors turn signals without having to delete the drl?
Thursday, February 07, 2013 7:08 AM
the mirrors has 3 wires. 1 blue, one white, and one black
Thursday, February 07, 2013 10:48 AM
I would think that there are instructions with the mirrors to tell you what is what. I would assume that one is ground and then one wire for either the front light or the arrow. If you can find the wire you can run them off the rear signal light wiring as they are separate. You can disable drls as well if you wish. Look in the sticky for the correct disable method for your vehicle year. (DRL sticky is in exterior forum)
Edited 2 time(s). Last edited Thursday, February 07, 2013 10:50 AM
Have a nice day.
Thursday, February 07, 2013 11:08 AM
blue is probably parking lights and white is probably turn signal.
Thursday, February 07, 2013 11:09 AM
Just test it off the battery.
Saturday, February 09, 2013 10:48 PM
i have a wiring diagram for this i was planning on making my own turn signal lights for my Cavalier
