Got a 4 channel kenwood kac-744. Wondering if I can hook up my subs and rear speakers to it, my speakers are 4 ohms I believe.
We need more info on your subs and speakers in order to make a proper recommendation.
Whats up people?
Oh and you should fill out your profile. Btw there is no more Pontiac so there will never be a 2011 Pontiac G8
Whats up people?
Yes you can. Channel 1 and 2 to speakers, channel 3 and 4 bridged to sub. (Assuming it can be bridged)
Sub probably won't be very loud, but that depends on the amp.
Speakers:
MAX Power 1000W per dual speakers
Electro-Plated P.P Injection cone
Butyl rubber sound
2-1/4" Midrange
30mm Tweeter
(2) 13mm Super Tweeters
30 oz Ferrite magnets
4 Ohm impedance
Continuous Input Power: 500 watts RMS
Peak Input Power: 1000 watts
Sensitivity: 90 dB
Frequency Response: 50 Hz-22Khz
SPECIFICATIONS
Speaker/Subwoofer Size : 6" x 9"
Design : 5-Way
Power Handling (RMS) : 500 Watts
Power Handling (MAX) : 1000 Watts
Power Handling (Combined MAX) : 1000 Watts
Sensitivity : 90 dB
Frequency Response : 50 Hz-22Khz
Impedance : 4-Ohms
Mounting Depth : 2-7/8"
Bottom Mounting : N/A
Cutout Diameter : 3" x 8-7/8"
Magnet Size : 30 oz
Approximate Weight : 8.4 LBS
Subs:
Pioneer TS-TRX1000 10" 250 Watts Peak Power Truck Riders 3-Way Bass Reflex System
Brand
Pioneer
Model
TS-TRX1000
Type
3-way Speaker
Speaker Size
10"
Component
Woofer Material
Injection Molded Polypropylene
Midrange
2-5/8" Horn Midrange
Tweeter
2-1/4" Horn Tweeter
Magnet Construction
38.8 oz. Strontium Magnet
Specification
Peak Power
250 Watts
RMS Power
100 Watts
Sensitivity
94dB (1W/1m)
Frequency Response
35Hz - 24kHz
Impedance
4 Ohm
whoa . . . when i asked for more info on your subs and speakers i meant the number of subs, model of subs, model of speakers. we can look up the info we need from manufacturers site.
from the info that i have on your sub I would recommend running one sub on the amp in bridged mode on the 3rd and 4th channel and then your front door speakers off of the amp instead of the 6x9s in the rear.
Whats up people?
