Where else can i connect my amp remote wire, i dont want to remove dash to get to HU....
ignition power will work just fine.
Anything that comes on when u turn the car on. U sound too lazy to do it right tho so I'm scared to think where and how u end up tapping for power. U got wires running throughh ur interior and fender don't u?
"You really need to staple your face shut"-THE Joey Baggs.
its a DD with high mileage. using factory HU and old stereo equip.
car is not worth me taking the time to remove dash. just using some stereo equip of have layin around
Well like I said, anything that is switched on when the key is turned on. It only needs a low voltage signal anyway.
ok ill check around, for igntion wire etc what color is it again?....is there a good feed thru in the firewall already that u could point out to me?
You shouldn't have to go into the firewall for the remote turn on wire. you should be able to get to your fuse panel and find a switched power source there. As for running the power wire, you can go through the grommet that is under the dash on the drivers side. Shouldn't be an issue getting a wire through that.
The windshield wiper fuse is what you want to tap into probably.
Has never failed me yet.
sndsgood wrote:god just take the 5 minutes to do it properly.
seriously theres less then 10 screws between you and completing it correctly. I doubt your time is worth that much.
I have a strange feeling he isn't even going to fuse it. and I see a power wire running through a fender lol.
