sooo, my alt is not working properly, and my battery died on me during rush our on the busiest road in the city. haha, I thought people were going to kill me. fun times...
It is only a 2 year old alternator, 160 amp rebuilt. Can it be fixed by anychance and save me money opposed to buying a new one. What seems to be the problem is the bolt the positive terminals attach to is loose, it wiggles and can slide in and out a bit. The external bolt is as tight as it will go. it's like it needs to be tightened from the inside. anyone have a problem like this before?
Im wondering what i should do about this. I will have an aprox 2000w system running and 2 batteries. So what kind of alternator am I looking for. If I can avoid spending $500 I would be very happy. I was thinking about that GM large case swap someone posted up here a while back. Would that be sufficient if i cant fix my existing alt?
Search local alternator shops, I bet they can pull it and fix that for fairly cheap. If when working properly, it kept voltage up, chances are you don't need a whole new alt.
yeah, my battery voltage drops when i start the car.
and Lanman, is it simple to replace the terminal post or would it need to be professionally done?
if you have torn into a case before it's not bad.
What does the cars voltage drop too when just starting?
Not on dash, with a real voltmeter? any idea?
I'll go find out for you right now.
car off its at 12.4 volts. Soon as I turn the car on it drops to 10 and then stays at 11.4
sound slike a dead cell in the battery....they will drop when you put a pull on it....
still need that bolt fixed on alt though.
can you borrow someones battery, drop it in as is and see if it starts...
May need a voltage regulator as well.
Weebel wrote:Im to smart to go to strip clubs.
well its a new battery, and i had it tested and its good. I think its just the alternator is not charging the battery at all. So everying is being powered by the battery and causing its voltage to drop. I took out the alternator and im going to order a new terminal post for it.
and the car runs with the new battery in it. just doesnt seem to be charging. When the car was running I tried disconnecting the negative terminal from the battery and sure enoguh the car shut off. So its gotte be a problem with the alt.
Sounds good. I'll get it tested.
Thanks guys
