98 chevy cavalier z24....Ok so changed the bulbs on the reverse lights,turn the car to on, put in reverse... no lights. So i pulled the bulbs out and looked inside the socket, the socket alot of gunk in it...cleaned the got out best way possible and reinstalled...still no lights.So i replace sockets with new ones from chevy and installed socket and bulb still no light even i checked for power in to each socket connector and was getting power while in reveser gear...so am baffled any help will be greatly appreciated
it's the switch. common as hell problem.
Liquor is not a drug John, liquor is not a drug.
how do i fix it, and were is it located really need it fixed cause.....exception is DUE....
is it a 5 speed? and if its the same as my 02... u gotta take the drivers side tire off and theres a sensor behind the wheel... and its for ur reverse lights
