High Output alternator - Audio & Electronics Forum
Thursday, March 18, 2010 6:37 PM
Anywhere to buy High Output alternator with higher amperage at idle and rpm's..The alternator shop here told me you can only have it at higher rpms.m but you will lose at idle???
"No greater love than this that he lay down his life for his friend"....John 15:13
Re: High Output alternator
Thursday, March 18, 2010 7:35 PM
No. That alternator shop is retarded. probably some old guy with old ways of thinking with NO knowledge of the car-audio bred companies that specialize in high output alts.
There are some very notable companies. mechman is the only one off the top of my head right this moment. They are not cheap at all. if you can't see the need to penny up on one of the known good brands, you can't afford a system big enough to require one.
In my family we teach that boys have a God-stick and girls have a Shame Cave. -John Stewart
Thursday, March 18, 2010 8:40 PM
DC Power Alts.
Iraggi Alts.
Mechman Alts.
Friday, March 19, 2010 4:15 AM
ohio generator if they are around.
and make sure you look at the specs, a 200 amp alt isn't going to do allot of good if it only puts out 200 amps at 6000 rpm's cheap alternators are like that, expensive alternators put out at thextra power at idle or very close to idle. so do your homework.
Friday, March 19, 2010 8:54 PM
if you wanna keep a low budget just get a alt. from a 96 alero off teh 3400 motor, it is a bigger alt and puts out alot more amps than the stock cav one, I picked one up from the wreckers for 60 bux everything just plugs in and the pulley on it has one or two extra ribs i forget but as long as you have it lined up its all good, if that bugs you just change the pulley lol
Saturday, March 20, 2010 1:26 AM
if he's going big enough with his system, the Alero alt that you are recommending that "puts out alot more amps" isn't going to cut it........ Do you fully understand WHY the high end high output alt companies cost so much, guy?
Saturday, March 20, 2010 5:02 PM
ok i understand..i had my system tested and the audio shop stated my volts are dropping down to 9 and i bkew my 100 amp fuse so they gave me a 150 circuit breaker and stated im pushing out 190 amps...so they said i needed an extra batter stinger which would cost 500 to put in and a volt meter and a new alternator. im thinking i should get better amp... and also is there a such thing as too much, cause i ordere the lanzar opti1232d but was sent the 1233d which claim 6000watt max and 3000rms and i know i dont need all of that..the amp was a hifonics brutus 1680bxi monoblock??any suggestions??????????
Saturday, March 20, 2010 5:12 PM
why couldn't that have happened when i ordered my pair of 1232ds?
please, pics and vids of install.
car audio noob since 1984.
Saturday, March 20, 2010 5:16 PM
lol..you want these..these things are monsters...i have a box filling up my trunk and the audio guy said thats not really big enough..my amp is nowhere near powering them enough and i already need to upgrade
Sunday, March 21, 2010 1:15 PM
Those subs are an SPL monster, but not so good for a daily.
Your car may do 13 sec @ 103 mph, but my car does 146db @ 35 hz.
Tuesday, April 13, 2010 6:39 PM
hey fellas, i highly recommend iraggi alternators, they have one for my sunfire 2000, the tech guy told me it's a 320 amp alt. capable of 15.5 volts with chilly weather but normal about 14.8 and 174 amps at idle, max amps 320 at about 2500 rpm's, but u can also get voltage regulator with in cab adjustabilty from stinger.price he quoted me was 479.. thats on my list.
