Okay, here's the situation. I'm bridging a 4 channel Eclipse amp. It's actually a 2/3/4 channel amp and has a switch to select what you are using it for. The problem I have is that I am only getting sound from one bridged channel. There is no sound from the other bridged channel. The amp has 2 RCA inputs. If I swap the RCA's, then the other bridged channel works. Is it standard to have to get Y adapters and hook up both RCA inputs for it to work? I thought by switching it to 2 channel mode, that it would copy the signal from the one set of RCA inputs.....
1999 Grand AM SE (Beater Car)
1997 GMC Sierra
2007 Honda CBR 600RR
2005 Honda TRX450R
what type of rca's did you get cuz i actually had this exact problem with mine i replaced the whole set of rca's ( Bought the stinger elite directionals ELI317 they were cheap for me
) and it would do the exact thing that you described i was so frustrated so i actually just switched negative and positive on the amp and now they all work i don't know how it worked because it doesn't make sense...
So ones side goes in the supposed positive and negative the other end is switched (vice versa)... so i don't know
Hope that makes sense kind of..
Yeah....don't do this:
~NiKki~ wrote:what type of rca's did you get cuz i actually had this exact problem with mine i replaced the whole set of rca's ( Bought the stinger elite directionals ELI317 they were cheap for me ) and it would do the exact thing that you described i was so frustrated so i actually just switched negative and positive on the amp and now they all work i don't know how it worked because it doesn't make sense...
Get another set, or even a 4 channel set and run them correctly. Bridging, while only using 2 speaker terminals, still is using both the front and rear outputs of the amp. Run 2 sets of RCA's(or a 4 channel set), get the full available signal to your amp, and get the full power potential out of it. DO NOT just split the left and right from a single set of 2 channel RCA's when bridging the amp.
In my family we teach that boys have a God-stick and girls have a Shame Cave. -John Stewart
yea i looked at my hook up again hahah sorry i was being dumb thats not what i did to fix it...the wires are the right way neg to neg pos to pos..it must have just came loose as i was running them...sorry ignore the message before
Cursed Cav wrote:Okay, here's the situation. I'm bridging a 4 channel Eclipse amp. It's actually a 2/3/4 channel amp and has a switch to select what you are using it for. The problem I have is that I am only getting sound from one bridged channel. There is no sound from the other bridged channel. The amp has 2 RCA inputs. If I swap the RCA's, then the other bridged channel works. Is it standard to have to get Y adapters and hook up both RCA inputs for it to work? I thought by switching it to 2 channel mode, that it would copy the signal from the one set of RCA inputs.....
Try using the left inputs on the amp only.
A(left) ->(left from deck)
B(left)->(right from deck)
Then turn the 2/3/4 switch to 2.
