Question:
I bought a tachometer from Glowshift, and it has four colored wires, an red, green, black, and yellow. I assumed the black was for ground, but I needed to know where the other wires went too.
Also, if anyone knows where I can find a wiring diagram for the actual gauge cluster itself would be nice. Thanks again.
EDIT:
Oh and my cav is a 01 2200. If anyone needed to know, thanks
Edited 1 time(s). Last edited Monday, November 16, 2009 4:13 AM
- Attachments
- IMG00021.jpg (472k)
I'm not going anywhere just yet
R.I.P. Jimmy "the Rev" Sullivan '81-'09
red - IGN +12v
yellow - headlight switch (lights up the gauge when you turn your headlights on)
green - signal wire. now for this one, chances are you'll need a tach driver, unless the gauge can be set to read 2 cyl. otherwise, summit racing sells the msd DIS tach adapter.
car audio noob since 1984.
ok thank you.
how about for an 03 cavy
i have an autometer tach i know its got settings for v8, 6,and 4
do the ecotecs also run on 2
for an 03 i would just get a new cluster, as it's plug and play.
timka03 cav wrote:how about for an 03 cavy
Either find a 00-05 Cav or Fire cluster or find an Autometer 9117 Tach Adapter to use with that tach
my cluster dose have an rpm gauge on it i was just planing on trying to make a custom cluster. i have all autometer gauges speed, rpm, gas, water, oil, boost, wideband, oil, i have alot of them and wanted to do something custom
if i have the rpm gauge on my car and wanted to put an aftermarket one on can i use the wire that the stock one runs off of?
stock signal for the gauges is serial data if im not mistaken, so no.
can a 00+ car run with the cluster removed?????
99 and older can but i heard 00+ can't is this true
JBO since July 30, 2001
