1999 Sunfire (9007 bulbs) to 1999 Cavalier conversion (9005,9006)
Library schem
95-99 Cavalier
Driverside
High Beam Positive = Dark Blue
High Beam Ground = Pink
Low Beam Positive = Orange (or Blue)
Low Beam Ground = Dark Blue
Passengerside
High Beam Positive = Orange
[u]95-99 Sunfire
Driverside
High Beam Ground = Green
Positive = Black
Low Beam Ground = Tan
Passengerside
Positive = Black
My conversion
Drivers side
High beam ground=
(Sunfire)green
(Cavalier)pink
Positive(+)=
(Sunfire)Black
(cavalier high beam+) Dark Blue
(cavalier low beam +) Orange or Blue
low beam ground=
(Sunfire) Tan
(Cavalier) Dark blue
Passenger side
High beam ground=
(Sunfire) Green
(Cavalier) Pink
Positive(+)=
(Sunfire)Black
(cavalier high beam+) Orange
low beam ground=
(Sunfire) tan
(Cavalier) Dark Blue
If I group the wires together and solder as they are above, does it look like it is going to work? Or is there a better DIY?
why dont you just unplug the the headlight harness from under the battery tray... then go to the junk yard and pick up the harness from the 95-99 cavaliers and just plug that in place if the 9007 harness..
Because I'm not that smart haha. I didn't realise you could do that. Thanx for the info L) That will make the sawp super easy
Thanx again man
Hey man. So your 100% sure the headlight harness is just plug and play? I"m drving 1hr and 1/2 to pick up the fornt end and have to assemble it in his drive way haha. just making sure it'll work
100 percent it will work. i promise lol
Haha thanx man. Its nice just to have that reassurance. I just don’t wanna get there and start swearing up and down when it will not work because it is supposed to rain tomorrow lol
worked for me when i did my 1996 cavalier and swapped it to the 02...
You all lied to me!! It didn't work:O!!! haha. Only thing I had to do was add a 12v constant to the blue wire on the high beam on the left(drivers side). Works perfect. 90% done the swap. Just need to fix a crack and repaint:>
still alot easier then wiring from the older procedure
