i found an old SS autotek amp in my basement today and i went to look up the specs for it online. Well, the model # on the amp said 750.1 and all the info i got told me that it was a mono amp? but the amp itself clearly has 2-channels in it.
I am i missing something or is something labeled wrong?
prolly internally bridged. where does it say it has 2 channels?
There are plenty of monoblocks on the market that have more than one set of speaker output terminals. They do this for one of two reasons, either it shares it's chassis/circuit board for manufacturing cost savings, or to allow the customer to wire in parallel directly at the amp and connect each speaker individually. At the terminals is it actually labels as right channel and left channel, or are there just terminals with = and - labelling without distinguishing between channels?
I don't care what company or specific amp it is, any time someone is naming their amp XXX.1, it will be a mono amp. The .1 is going to indicate how many channels the 750 watts are split up to.
In my family we teach that boys have a God-stick and girls have a Shame Cave. -John Stewart
it says speaker output then below that there are just lables marked as + and -
so it is a mono amp with 2 speaker outputs then?
so by wiring one sub to each speaker output am i putting a 4 or a 2 ohm load on the subs?
that depends on the amp. try to find out if its internally paralled. if so then if you hook up 2 4ohm subs youll be at 2 ohm,.
how would i see if its internally paralled or not?
Found a little info on it. It is a mono block amp that was produced in 06 and no longer avail. Can hook two 2ohm sub para into the speaker terminals for a 1ohm load. They are designed ths way for ease of installation. Product info below.
750W 1-Channel A/B Class Mono Amplifier
750W RMS x 1-Ch @ 1-Ohm
500W RMS x 1-Ch @ 2-Ohms
325W RMS x 1-Ch @ 4-Ohms
Includes Remote Mountable
Bass Control
SEPP A/B-Class Super Sport Amplifier Designs
Illuminated, Large New Design Autotek Logo
Super Sport ASPS MOSFET PWM Power Supply
For Instant Maxx Current Ouptut
1-Ohm, 2-Ohm, 4-Ohm Capable A/B Class Mono Block Amp
Rugged PRO-FITM MOSFET Audio Outputs
Super Sport Amp Protection with System
Diagnostics LEDs That Guard Against: Current / Amperage Overload, Short Circuits, Thermal Overload, DC Offset, Silver Preamp Level RCA Inputs
Daisy Chain Line Outputs
Mono Blocks Include a Remote Bass Control
Low-Pass Adjustable: 60Hz to 150Hz
Include Variable Subsonic Filter (15Hz to 55Hz)
Controls Adjustable +12dB Bass EQ @ 45Hz
Input Level Control: 6V
Oversized Speaker Terminals
o ok that helps out alot thanks, so this appears to be a pretty decent amp
