Key Fob FUBAR - Audio & Electronics Forum
Key Fob FUBAR
Saturday, January 31, 2009 7:27 AM
OK so the audio installation I did went in smooth as could be. I have a problem that is really odd now. I hit my lock button on the keyring and the car chirps kind of like when you lock the car only it flashes its lights and keeps chirping like it would in alarm mode. I hit the alarm button and it is loud like the alarm should be. I replaced the keyring batteries and no change. If it helps, when it got down to -16 here in ohio my car battery died while I was in class. Being stranded and freezing on a campus kinda sucks. Anyway is there a specific fuse I should check? I did the "push both lock and unlock for 7 seconds" that the keyring said as well. This is a 2000 SF 4 Door
Re: Key Fob FUBAR
Sunday, February 01, 2009 9:48 AM
more details needed for sure
Which keyfob? Factory or aftermarket alarm?
What audio did you install?
Re: Key Fob FUBAR
Monday, February 02, 2009 1:39 PM
if your talking about the factory key fob, in order to reprogram it, you need to go to the dealer and have them reprogram it with the tech2.
that "holding the lock and unlock for 7 seconds" is only for 95-99 models.
01' Z24 5 speed
422whp/400wtq
T4 Turbocharged
Built LD9
HP Tuners
